Broken Door Panels
Old Jun 11, 2014 | 11:41 PM
Duke123's Avatar
Duke123
Cruising
Default Broken Door Panels
Any ideas on how to fix the broken door panels on my 93? I've seen the metal brace and zip-tie ideas, but mine are broken at the top and bottom of the clips. Thanks for your help!
Old Jun 12, 2014 | 02:06 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I've been very successful at reapairing cracked chipped sections on my '88 Vette door panels with JB Quick over/under and a layer of fiberglass screen.
Old Jun 12, 2014 | 09:30 AM
GKK's Avatar
GKK
I used the Zip Tie method for that same repair.
I drilled two holes on the top edge and one hole in the rib then, I inserted a zip tie and snugged it down.
Use a thick zip tie, (minimum 8" long) or it won't be strong enough. Also, don't pull to hard since the plastic might be brittle and break apart.
Old Jun 12, 2014 | 01:24 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
i have had good luck with a soldering gun on high heat and a piece of similar plastic. heat up both pieces and stick in the fill piece and it will melt together just like soldering, just doesn't flow like solder. just heat, melt, fill, move. repeat.
Old Jun 13, 2014 | 09:43 PM
Duke123's Avatar
Duke123
Cruising
Thank you very much! I will give these ideas a try.
Old Jun 13, 2014 | 10:07 PM
rochhound's Avatar
rochhound
whoooooooa the best way to fix panel cracks is (lord fuzor) adhesive with cloth backing
permanet fix
To Broken Door Panels
