Problem with Turn Signal
Old Jun 13, 2014 | 11:39 AM
85kindofguy's Avatar
85kindofguy
Default Problem with Turn Signal
Hey forum i have an 85 and I have had some problems with the left turn signal. When I first start the car, the left turn signal light will turn on but it won't blink. After having the car running for awhile the turn signal works fine. Do you guys have any idea what is causing this? Could it just be a bad bulb? Any help you guys could provide would be appreciated.
Old Jun 13, 2014 | 12:02 PM
Annoyed's Avatar
Annoyed
Now that's weird.
I'd start with switching the front bulbs from left to right - right to left.... and then pray to an imaginary god for 45 minutes asking for help & luck before starting the car & testing them out.
Then I'd switch the rears around and if that doesn't work, start a thread about it on CorvetteForum (oh that's right, you've already done that).
What happens when you indicate with just the ignition on?
Old Jun 13, 2014 | 12:18 PM
hooked073's Avatar
hooked073
When it is acting up walk around the car and see what lights are on. Also take notice of the brightness of the bulbs and notice of anyones that should not be lit. When running your volts and amps increase so weak circuts show up. If all bulbe seem ok replace the T/S flasher
Old Jun 13, 2014 | 12:35 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
My guess... faulty flasher.
The picture below is one I did for a 69-73 but your turn signals work the same way.
When you click the signal on, power to the side you clicked to is diverted from the standard lamp input to the flasher side. So, when you have the signal on you should have continuity between the side you clicked to and the flasher wire. (a way to test the switch).
Old Jun 13, 2014 | 12:39 PM
bogus's Avatar
bogus
I agree with Willcox. I would also clean out all the bulb sockets, because they do get rusty over time.
Old Jun 13, 2014 | 02:27 PM
85kindofguy
With just the ignition turned, the light turns on solid but it does not blink. After the car runs for a bit then it works just fine.
Old Jun 13, 2014 | 10:45 PM
0Willcox Corvette
Former Vendor
I understand this. but.. the flasher works from what is called a beryllium switch. The current draw on the circuit causes the beryllium contact to curl (in the flasher).. when it is curled it cools and flips back down. This is what causes the flash.. I would replace the flasher first.. and see if the problem goes away.
IHMO,
Willcox
Old Jun 14, 2014 | 03:32 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Ben,
All this science on flashers is cool and all, but you never mention if the right turn signal works. Does it? Turn ignition switch to on and see if the right side works. The hazards use a different flasher unit that works differently. Try the hazards to check all the bulbs. Let us know what you find.
Old Jun 14, 2014 | 11:55 AM
85kindofguy
The turn signal on the right side works just fine.
Old Jun 14, 2014 | 12:54 PM
0Willcox Corvette
Former Vendor
Originally Posted by Ray Quayle
Ben,
That is a very good point..
So if one side is working and one side not, I would then start testing at the steering column connection. Testing for power going in the switch and power coming out. This would narrow it down quickly.
To Problem with Turn Signal
