Detent cable for transmision
Old Jun 15, 2014 | 11:28 AM
bigj177's Avatar
bigj177
Default Detent cable for transmision
Where can I pick up a detent cable/ kick-down cable for 1990 corvette 700r4 transmission . Would regular parts stores have it or is it something you would need from the dealer. Just had transmission redone and I want to replace it.
Old Jun 16, 2014 | 12:36 AM
Cliff Harris's Avatar
Cliff Harris
You might want to read this thread:
http://forums.corvetteforum.com/c4-t...ally-ugly.html
I have heard that the newer ATP Y-747 cables are OK, so it appears that they fixed the problem.
Old Jun 16, 2014 | 05:06 AM
bigj177's Avatar
bigj177
I don't need the shifter cable. I need the cable that goes to the throttle body to the transmission. That link shows the cable for a shifter cable
Old Jun 17, 2014 | 01:17 AM
Cliff Harris
You said detent cable. That's what I showed you.
What you want is a TV (Throttle Valve) cable. Obviously a completely different thing.
Old Jun 17, 2014 | 10:13 AM
bigj177's Avatar
bigj177
Sorry for the misunderstanding. I actually went to the dealership and 57 dollars later I have the cable.
Old Jun 17, 2014 | 10:39 AM
WW7's Avatar
WW7
I believe a TV cable and a Detent cable are the same thing..When I looked them up I get the same picture for both searches..There are only three cables I know of on the TB, the TV cable, the throttle cable, and the Cruise control cable..WW
Here it is, called by both names
http://www.monstertransmission.com/7...le_p_6132.html
Old Jun 18, 2014 | 02:57 AM
Cliff Harris
The detents are the shifter parts inside the transmission. The detent mechanism is called a "rooster comb", which I think is a very descriptive name. There is a roller on a spring that drops into the detents and that's the clicking sound you get when you shift from gear to gear. The detent mechanism is in the lower right corner of this picture (sorry for the quality -- not my picture):
The TV cable causes the transmission pressure to vary with throttle opening. It has NOTHING to do with detents.
Old Jun 18, 2014 | 06:29 AM
WVZR-1's Avatar
WVZR-1
I'm sure the parts guy/gal understood your needs. Your original post did quite well actually, I believe most understood and TV, kick-down, detent have been used (maybe incorrectly) synonymously for years. I surprised Cliff didn't pick up on it.
To Detent cable for transmision
