91 Vette l98....good mods..
Old Jun 17, 2014 | 03:42 PM
Flo2323's Avatar
Flo2323
8th Gear
Default 91 Vette l98....good mods..
I've Ben wanting to mod my vette....it's a l98 tpi any good/affordable suggestions??...
Old Jun 17, 2014 | 03:51 PM
TA's Avatar
TA
The stock TPI intake and exhaust are both very restrictive. These areas would be a good place to start. When I did the first round of mods on my 91 this is where I saw the biggest gains.
Old Jun 17, 2014 | 04:03 PM
Flo2323's Avatar
Flo2323
8th Gear
I was looking online at the vortex ram air it's like $170, and exhaust do you mean headers,cats the whole nine??, what about ECM tuning??
Old Jun 17, 2014 | 04:18 PM
GKK's Avatar
GKK
Vortex RamAir is not worth the price. Just cut the metal louver section out of the stock air lid cover and install any cotton gauze air filter you want for better airflow.
The Intake manifold and aftermarket Runner tubes can be ported to allow more airflow also, Long tube Headers really wake the L98 engine up!...
Old Jun 17, 2014 | 04:21 PM
Flo2323's Avatar
Flo2323
8th Gear
The Intake manifold and Runner tubes can be ported to allow more airflow also, Long tube Headers really wake the L98 engine up!...
Any good/affordable long tubes??
Old Jun 17, 2014 | 08:36 PM
TA's Avatar
TA
When I said the intake was restrictive I was referring to the runners, plenum and intake manifold. You can port the manifold and plenum, but the runner materials is very thin so there's no room for porting on them. Its pretty pricey, but many chose to replace the manifold and runners and port their existing plenum. As far as the air intake I'd just cut the louvered area out of the stock cover as GKK suggested.
As far as the exhaust, headers are definitely the biggest gain. Hedman and Hookers are fairly reasonable ($500-600) and other manufacturers go up from there. The rest of the exhaust is also pretty restrictive with the two y-pipes and a single cat design. If you're on a budget the LT1 system is a nice upgrade as it has true duals and larger diameter pipes.
You have to decide what the goals are for your car. If your just looking for a modest increase in power then the exhaust and intake mods mentioned might fit your bill. If you're looking for substantially more power then at some point you'll start considering aftermarket heads/cam and other intake options.
Old Jun 17, 2014 | 09:28 PM
Flo2323's Avatar
Flo2323
8th Gear
Thanks i will take into consideration
Old Jun 18, 2014 | 10:00 PM
ANTI VENOM's Avatar
ANTI VENOM
NOS! Yep, it even works on an L98.
Old Jun 18, 2014 | 10:04 PM
playsdixie's Avatar
playsdixie
there are several threads as to what mods work and what ones dont...don't waste your money......it takes a few bucks to make it faster....no quick fixes.... good luck...
Old Jun 18, 2014 | 10:13 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Does your '91 have an A4 or MN6?
What are your power goals & usage?
Old Jun 18, 2014 | 10:59 PM
l98tpi's Avatar
l98tpi
Max G’s
and what is your budget? Is affordable $100 or $1,000?
Old Jun 19, 2014 | 12:36 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
http://temp.corvetteforum.net/c4/vader86/
To 91 Vette l98....good mods..
