Low Oil Light ?....
Old Jul 23, 2002 | 02:40 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Default Low Oil Light ?....
About a month ago I got a "low oil" light..checked and needed 3/4 qt...I had just returned from an 1800 mile trip so I chalked it up to that...Today I start up my baby and got a "low oil" light again which stayed on ..thought it odd since I had my oil changed last week...shut off the car and checked the oil...the dipstick showed perfect...started back up and NO light..ran some errands and no light again...WTH...could it be a bad sensor ?.. thanks all..
Old Jul 23, 2002 | 04:00 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Low Oil Light ?.... (golfboy1)
Mine comes on sometimes for no reason. I just restart the car and it almost always goes away. I am thinking a bad sensor is the cause.
Old Jul 23, 2002 | 04:05 PM
TrplBlk01's Avatar
TrplBlk01
I have the same issue. No answer though.
Old Jul 23, 2002 | 04:53 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Default Re: Low Oil Light ?.... (blk91)
O.K. guys..I'm taking her in next monday to replace the sensor..parts, a couple of quarts of oil, labor and tax...$70.00...I'll post the resultsafter I run it for a while..this may qualify as the least expensive repair I've done... :D
Old Jul 23, 2002 | 06:22 PM
RichS's Avatar
RichS
The sensor is only like $30 and just unscrews out of the oilpan. Very simple job!
Old Jul 23, 2002 | 09:03 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Default Re: Low Oil Light ?.... (RichS)
Someday I'll have a place to do it and some ramps too... till then, oh well.... thanks
Old Jul 24, 2002 | 06:32 AM
VETTENV's Avatar
VETTENV
Cruise-In V Veteran
Cruise-In VI Veteran
I'm pretty sure you can get the sensor at Discount Auto, Pep Boys, ect for less then the dealer. I haven't changed mine out because I just changed my oil recently also( you'll have to drain all the oil out). Besides mine doesn't happen all the time and if you do shut the car off and restart so far mine goes away every time. :yesnod:
To Low Oil Light ?....
