X Brace Mounting on 96 coupe
Old Jun 18, 2014 | 10:53 PM
joebuckSR's Avatar
joebuckSR
Default X Brace Mounting on 96 coupe
Bought an X brace from a vert want to mount on my 96 coupe how difficult have all mounting bolts, looked underneath see that holes for the front but none in the rear. Can someone give me some advise as to will this x brace increase the handling and is it worth the trouble.
Old Jun 19, 2014 | 09:01 AM
c4cruiser's Avatar
c4cruiser
You will have to drill holes at the rear corners and use nutserts to be able to bolt the X-brace in place. IIRC, there are two bolts per corner. When the 'vert frame was built. the nuts were encapsulated on the inside of the frame rail.
The convertible also had studs that went thru the bottom of the floor pan that fit through the holes in the rear half of the X-brace. This provided additional rigidity to the body.
One thing about the X-brace installed on the coupe is that you will lose an inch or so of ground clearance. The 'verts sat slightly higher because of the brace.
Old Jun 19, 2014 | 12:31 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
This is exactly what Chris Petris taught in a C4 class I attended.
Old Jun 19, 2014 | 08:53 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
There are 4 bolts at each corner, plus the 2 smaller studs on each side just behind the "X". You will need the aluminum spacers for the back, or fabricate them.
If you want extra rigidity, box them in like this:
To X Brace Mounting on 96 coupe
