Cut-back plugs?
Old Jul 23, 2002 | 04:47 PM
TheCorvetteKid's Avatar
TheCorvetteKid
Default Cut-back plugs?
This may sound like a stupid question, but what are 'cut-back' spark plugs?
Everyone keeps saying how it's a good modification, but I don't know what it is. Can somebody please explain for those of us who don't know? Pics would be great too...
Thanks.
:cheers:
Old Jul 23, 2002 | 04:50 PM
scorp508's Avatar
scorp508
Grrr... hold on, I have an image here somewhere.
[Modified by scorp508, 3:50 PM 7/23/2002]
Old Jul 23, 2002 | 04:59 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Default Re: Cut-back plugs? (TheCorvetteKid)
Description:
Take a look at the ground electrode on a normal spark plug. See how it completely covers the center electrode? The spark jumps the gap betweek the electrodes and not much of it is exposed to the air-fuel mixture. Now Imagine if you cut off the ground electrode so that one half of the center electrode was visible. A lot more of the same spark is now exposed to the air-fuel mixture.
Use a cut off wheel on a dremel or other rotary tool, clean up the cut with sandpaper, gap the plug and put them in.
On my car it probably took 30 min to do it and another hour + to put them in the car (1988, L98)
Old Jul 23, 2002 | 05:07 PM
TheCorvetteKid
Default Re: Cut-back plugs? (jaa1988)
OK, that makes perfect sense - expose more of the spark to the air/fuel charge by removing some of the ground electrode. Brilliant!
But, wouldn't the same effect be achieved with those new Bosch +4 platinum plugs? They have 4 ground electrodes all placed around the centre electrode. The centre electrode is totally exposed.
Either way though, I think I'll try this before I put my plugs back in.
Thanks guys.
:cheers:
Old Jul 23, 2002 | 05:32 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Well that's the principle of the Bosch plugs anyway.
My time slips show a 1mph gain in trap speed from cut-back AC Delcos vs Rapid Fires.
I've never tryed the Bosch 4-electrode; cut-back (got a pic on my site) works for me.
Old Jul 23, 2002 | 06:11 PM
scorp508's Avatar
scorp508
Do you want one BIG spark or one little one? Electricity only follows one path at a time.
ConeKLR's Avatar
ConeKLR
Default Re: Cut-back plugs? (65Z01)
This is an old hotrodding trick. It's been around for years.
:yesnod:
Not only can you do this, You can also dial in your plugs. Ever hear of that? :yesnod:
Dialed in plugs are plugs that when torq down has the open area of the tip and prong facing the more open area of the chamber. If the plug sat in the middle of the cylinder like a Hemi motor it would not matter much.
The plugs are dial in using washers to adjust where it stops when it is tighten down. gabeash!
:lol:
[Modified by ConeKLR, 5:19 PM 7/23/2002]
Old Jul 23, 2002 | 06:13 PM
ConeKLR's Avatar
ConeKLR
Default Re: Cut-back plugs? (scorp508)
Some people think all four fire up at the same time.
:crazy:
Old Jul 23, 2002 | 06:14 PM
65Z01's Avatar
65Z01
Default Re: Cut-back plugs? (ConeKLR)
The cut-back "trick" is realy easy but dialing in (or indexing) on an L98 would be too much effort for me.
Old Jul 23, 2002 | 06:21 PM
ConeKLR's Avatar
ConeKLR
I did not say to do this. Was just bringing it up, you know trivia. :D
Have never tried it on an L98. But on my past Muscle cars, that a different story. :yesnod:
Old Jul 23, 2002 | 06:53 PM
TheCorvetteKid
Actually, for me indexing the plugs would not be such a bad idea since I'll have the heads off of my car soon. But is there any real advantage to it? What kind of numbers are we talking about here - 5hp or maybe 8hp at the flywheel? Is it worth the effort?
I think that Summit Racing sells a plug indexing kit. Do you need this kit, or would any properly sized washers (of varying thicknesses) do the trick?
Old Jul 23, 2002 | 07:33 PM
65Z01's Avatar
65Z01
With our Al heads you need crush washers for the plugs so not sure how easy it would be to index the plugs.
I too have not heard how much of a HP gain to expect from indexing them.
Old Jul 23, 2002 | 11:17 PM
tkrussell's Avatar
tkrussell
Indexing plugs was reported in several build-up volumes to be worth 5hp at the 400-450hp level. No report of indexing vs. cut-back plugs (or both) is available.
Anyone with a dyno and an inquiring mind? Why not add the MSD box to the test and we can all benefit from some hard data.
If one had the heads on a bench, indexing would be a snap, and you could have a spare set of plugs ready to go. On the car, it is a royal PITA for the right rear plugs unless you have long headers and small fingers. For an extra "free" 5-10 hp I'd walk on hot coals, though, so I cut back the plugs, index, and use MSD..
Old Jul 24, 2002 | 01:34 PM
ConeKLR's Avatar
ConeKLR
Default Re: Cut-back plugs? (tkrussell)
Make sure you verify whether indexing can be done on the L98 type heads without leakage or stripping the threads. I have never done it before so I can't say.
To Cut-back plugs?
