Rough start up when hot
Old Jun 21, 2014 | 05:50 PM
nitroaddicted's Avatar
nitroaddicted
Default Rough start up when hot
When engine temps are up to about 200+ and I try to start the car, it doesnt want to stay running. I have to keep on the gas for about 20 seconds and then it will return to a normal idle and run properly. During those 20 seconds it sounds like its stumbling maybe missing and puts out black smoke from exhaust. Im thinking fuel pressure regulator or ignition coil, thoughts?
Old Jun 21, 2014 | 07:15 PM
tombrammer's Avatar
tombrammer
Fuel pressure could be the problem, sounds like your running rich at idle, check your pressure to see what you have. I runs fine when cold because it needs more fuel but when warm that is no longer the case.
Old Jun 21, 2014 | 09:31 PM
TerryOlson's Avatar
TerryOlson
I have a similar issue with our '84, which was the last year of throttle body injection, but I suspect the problem - TBI or TPI - might just be vapor lock. Not sure there's a great solution for it, but it can be annoying. I'll be interested to see what others suggest.
Old Jun 21, 2014 | 11:41 PM
nitroaddicted
Ill get a pressure guage on it. I know its fine at key on. Ill check it running. Probably turn it down a bit.
Old Jun 22, 2014 | 02:19 AM
Cliff Harris's Avatar
Cliff Harris
A bad coolant temperature sensor (the one located on the front of the intake manifold) or wiring problem will cause this problem (a corroded pin in the connector or broken wire). If the ECM thinks the engine is cold it will richen the mixture to help the engine run better.
To Rough start up when hot
