86 a/c
Unplug the connector to the switch. Crank your car, turn on the A/C. Place a jumper across the connector terminals. If the compress clutch pulls in, you have a bad switch or low freon pressure (could also be high, but most likely low). Everything else is probably working. If you have freon gauges, connect to monitor pressure on the low side. If low side pressure is 1.7 kg/cm2 to 3.8 kg/cm2 (25 to 55 psi), the pressure switch is bad.
You can do the jumper test in about 10 minutes.
I suspected the R12 had leaked out due to non-use, and had it looked at by an AC shop last week. Sure enough, the only issue they found was serious leaks at the front seal and also the seals at the rear of the compressor where the lines attach. I'm trying to find a place that will reseal my original compressor, as I don't want to change it.
This does not include ABS, transmission or accessories like A/C.
Thanks!
If you have gas to spare, you can try to find the leak by attempting to put a can in it, but it will be difficult with essentially nothing to get the compressor to suck in a can. If you have a vacuum pump, you may be able to get it below atmosphere so that some suction occurs. Bad seals and ruptured hoses usually show up rather quickly once there's some gas in it.
!! I don't have a vacuum pump, but could I momentarily bypass the cycling switch to energize the clutch, with the can punctured letting R-12 into the low side? I just ordered the 1/4" to 3/16" high side adapter for my gauges so I can check the system later on. Would the fact that it had 16 psi in the system B4 I energized the clutch indicate a small gradual leak such as the compressor seal?
!! I don't have a vacuum pump, but could I momentarily bypass the cycling switch to energize the clutch, with the can punctured letting R-12 into the low side? I just ordered the 1/4" to 3/16" high side adapter for my gauges so I can check the system later on. Would the fact that it had 16 psi in the system B4 I energized the clutch indicate a small gradual leak such as the compressor seal?My 1985 still has R12 and I have added R12 to it. According to the 1985's service manual you test the charge by feel. Don't have my service manual with me, would need it to tell you where you place your hands to feel how cool the air conditioning pipes are to identify if it needs R12. My 1985's compressor has always worked pumping R12, never let it get low enough for the pressure switch not to let the compressor run.
You may be able to add a can of R12 to the system without the compressor running. If it takes the can of R12 because of the pressure of the R12 to inject it into your system, now start the car and see if the compressor will run. If it does not leave the air conditioning on and hook up another can of R12 and inject it into the system.
Last year I replaced a compressor, accumulator, and orifice tube in another car. I vacuumed the system with the "loan a tool" from Auto Zone. It was a brand new vacuum pump and no cost to use, only deposit to take it out of the store.
I added a can or two of refridgerant first and then started the car and added more, still cooling.
My 1985's GM service manual does not have information on using gauges to check the R12, just the hand feel method.
If my math is correct. Figuring 2.75 LB is a full charge (3.67 12 oz cans) I added 12oz's (which may be a slight over charge base on the previously mentioned pressure temp relationship) The system had ~ 80% of a full charge, B4 I started. The cycling switch must shut down the compressor when the system leaks down to ~ 90% of a full charge??? But I'll re check with gauges when I get my adapter and adjust the charge accordingly. Thank to all contributors!
