Trouble Codes, and Running Poorly
Old Jun 22, 2014 | 01:53 PM
Azriel's Avatar
Azriel
Default Trouble Codes, and Running Poorly
Hey, I've got an 88, Auto, stock
I seem to have a few issues, mainly with the way the car runs.
It seems to be showing codes:
Code #21: Throttle Position Sensor Circuit High.
Code #32: EGR System Failure.
Code #34: Mass Air Flow Sensor Low.
On to the behavior. It starts and drives fine. Idle sits at around 600-800 in neutral. In terms of driving, it accelerates at a normal pace at light throttle, but at WOT, it's like I'm driving a moped. There's seriously no power.
I thought it might be a timing issue, so I got my timing light and checked my timing. The timing line is jumpy. It's not stable and jumps around a bit.
Spark plugs are fine, wires are fine, distributor cap and rotor are new. I'm really not sure what to check into. I don't want to blindly replace parts.
Any advice?
Old Jun 22, 2014 | 02:50 PM
hooked073's Avatar
hooked073
I think the answers are in your codes esp the esp code 34 and 21. I would work on the codes and go from there. I do not have a way of scaning the diag tree for the code repairs so if you do not speak up and someone on here may be able to do that for you. I would not go any futher till I got this information
Old Jun 22, 2014 | 02:54 PM
Azriel's Avatar
Azriel
I also meant to mention that I attempted to re-set the idle, but the car won't run with the IAC valve unhooked.
Old Jun 22, 2014 | 03:05 PM
hooked073's Avatar
hooked073
Does not surprise me dig into thouse codes you know that they are a known problem and that is where you should alwas start.
Old Jun 23, 2014 | 01:50 AM
Cliff Harris's Avatar
Cliff Harris
You can eliminate the MAF by unplugging it. The engine will run just fine with it unplugged.
I suggest resetting the error codes to make sure you're really looking at a problem. Unplug this connector for a second or so:
Old Jun 27, 2014 | 07:51 PM
Azriel's Avatar
Azriel
I disconnected the battery to clear the codes, and the only one that remained was code #32, EGR failure. What's a good way of testing this without just replacing parts?
Old Jun 27, 2014 | 08:02 PM
Christian95's Avatar
Christian95
Just thought I'd ask, did you unplug the EST wire?
Old Jun 27, 2014 | 09:47 PM
Azriel's Avatar
Azriel
I...no. No I didn't. Wow.
Old Jun 27, 2014 | 09:52 PM
Christian95
I've done that a couple times haha always messes with my mind at first
Edit: I forgot to mention that the problem you mentioned with wot sounds like the tps. I had the exact same problem. Completely bogged at wot. Set my tps and it was fine after that.
Old Jun 27, 2014 | 10:07 PM
Azriel's Avatar
Azriel
And one of the vacuum lines to my EGR is cracked. So, that seems to solve all my problems! Is there a place to buy the EGR vacuum lines or am I pretty much on my own for a DIY solution?
To Trouble Codes, and Running Poorly
