high idle
Old Jun 24, 2014 | 09:26 AM
msarles1's Avatar
msarles1
Default high idle
anyone experiance a high idle while driving but will idle back down after a complete stop. i can go 30 mph without touching the gas pedal. a friends 86 does the same thing. it just started this on sunday. no codes.
Old Jun 24, 2014 | 10:42 AM
playsdixie's Avatar
playsdixie
could be lots of things...what year?....I start looking for vac leaks....I can't hear em so I use tb cleaner to check the lines...
Old Jun 24, 2014 | 10:48 AM
84wuzmy1st's Avatar
84wuzmy1st
TB butterfly's sticking, maybe do a TB clean?
Old Jun 24, 2014 | 11:27 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Could be many things including: dirty TB or IAC or vac leak.
Old Jun 24, 2014 | 12:02 PM
msarles1's Avatar
msarles1
last year i replaced all injectors, intake gaskets upper and lower. new throttle body. its a 91. it just started this sunday . ive went over it three times. new 02 sensor last year . only thing left original is tps, iac motor newer ecm. i started it up sunday and it reved up high and stalled. restarted ok.
Old Jun 24, 2014 | 01:07 PM
playsdixie's Avatar
playsdixie
I guess i'd try cleaning the iac and the port it goes in....
Old Jun 27, 2014 | 10:46 AM
eatmydst1234's Avatar
eatmydst1234
Pull the throttle body and clean it real well then go through the minimum idle procedure as outlined in the sticky section above. Will grab a link in a minute
Edit: here's the link. http://web.archive.org/web/20040203095130/https://www.corvetteforum.com/techtips/viewsubtopic.php?SubTopicID=55&TopicID=2
Old Jun 27, 2014 | 11:16 AM
msarles1's Avatar
msarles1
Edit: here's the link. http://web.archive.org/web/200402030...D=55&TopicID=2
thanks!!
To high idle
