I have searched the forum, but have not found a thread that is quit on point. I have a 95' base C4 coupe. When the car hits broken surfaces, I get some pretty good bump-steer. If I am in a turn, I get real serious bump-steer...front end wants to walk to the outside big-time! You can feel a real wiggle in the steering wheel when this happens. The result is a real sense of "not fully in control of the car's future".
New tires, 85,000 miles. Car tracks and handles perfect otherwise. No clicks or catches in the steering. No slack in steering, and no rack leaks.
The only "play" I can spot appears to be the rack end bushings going to the tie rods. It appears to be equal to both sides, but is only felt when hitting bumps (the bigger, the worse, and in turns even more so).
Replacing the rack looks like a $750 repair, so I am looking for any input I can get before I pull the trigger on that deal. HELP.
I have also tightened up the ends on the steering shaft, which was a large improvement! But the car feels so upset on bumps in turns, there has to be more. Any help would be Very appreciated.This is my first Corvette, but I have to believe this is NOT how they handle. If this were a normal car, I would think the steering damper was defective.
Kelly
Kelly
Try higher tire pressure that helps reduce the wandering effect on uneven road surfaces, I run my tire pressure at 38 psi because of that and the car is much more pleasant to drive on the poorly maintained highways our taxes pay for.......
Keep the camber settings standard but you can help counteract wandering by more positve caster, I run 6 deg positive caster and that has helped too.
You might also take a look and see if your shocks are bad.
When they go, they can make it feel really bad over bumps (unstable, skipping/hopping on bumps, vibration, steering wheel oscillation, etc) . If shocks, you may also see some cupping on the tires.
Kelly
What you are describing is not the definition of "Bump-Steer". What you are experiencing is a damping issue w/the front of the car.
Bingo.
Additionally, I added an RD Cross Brace to mine to help reduce front end "Jitters" when encountering a bump during turns. It helped.
Kelly
Sounds like your car may have shock issues. Check out the thread I started the other day. I am going to go with the Bilstein Z51 B8's on all 4 corners for my base model. They bolt right in and are much stiffer than the B6's (non Z51). I'm sure if I replaced the shocks with B6's like the factory installed, I would feel an improvement. The stiffer shocks will give the car that much more handling performance at the sacrifice of a 'softer' ride. Look at the specs QCVette posted. Post your results....
Checked system today. Front actuators act as should when tested off-shock. I failed to mention that I have the FX3 set up. Some evidence of oil leaks, and no codes. Found a pair of fronts in stock (all the pain I want to deal with right now), and pulled the trigger at $190.08 each, free shipping. Should have them on beginning of next week. Also added a small bottle of Lucas Steering Rack product as an abundance of caution(steering already feels much better). I will let you know how things work out. Thanks for the feedback.
Kelly
Reason: FX3 update to info.
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
You might also take a look and see if your shocks are bad. When they go, they can make it feel really bad over bumps (unstable, skipping/hopping on bumps, vibration, steering wheel oscillation, etc).
Look for signs of leaking seals or ID the shock type/brand.
Thank you all for your input. When the old Bilsteins were removed, they proved to be absolutely worn out! Installed new selective ride control Bilsteins. Wow! All is well, once again.
Kelly
