slight hiccup
Old Jun 28, 2014 | 10:50 PM
dglad's Avatar
dglad
Default slight hiccup
Hi forum I have a 95 vette 82k just had wires plugs opti done car is running great but I notice a slight hiccup once in awhile at higher speeds maybe 65-70 with cruise on didn't change ignition coil or module should I any help greatly appreciated thx.
Old Jun 29, 2014 | 12:07 AM
don hall's Avatar
don hall
It is always wise to review the work quality of the most recent
repairs......plug wires tight on plugs and opti? You didn't mention
"Check Eng" light being displayed, so no codes should be set, but
checking for codes still might be prudent.
What brand of opti was installed?
Fuel supply could be the culprit....filters (pump & inline) changed?
Running some Techron (20oz) through a half-full tank may help.
Just mentioning some simple items before you start changing parts.
Old Jun 29, 2014 | 07:43 AM
dglad's Avatar
dglad
Went with oem opti ngk plugs I'll try the techron car did sit it for awhile thank you.
To slight hiccup
