I called comp cams and got their recommendation of cam for my engine. Wanted to make sure it all looks right. Also talking with a dealer for AFR heads and about to finalize purchase but still on edge about the head size.
383 Stroker in my 1989 manual vette
Need a lot of high end rpm because used for almost entirely Road Racing NASA/SCCA. Want to be able to hold a gear close or to 7000 RPM. Also in Autocross I always need more 2nd gear (3rd hardly ever worth shifting for).
Intake will be a USM ported Holley Stealth Ram
AFR Head either 210cc or 220 (would like to hear recommendations. my thoughts are go bigger in case of future modification)
Will be using a 5.7 Rod (thinking of a 6. I want reliability over power)
Thing that makes me a bit weary is it looks too small. I am going to use a 1.6 Roller rocker so the specs change to 251/258 550intake 568 exhaust, but still seems a bit small... He said it makes power from 2000 to 6300. Could I hold a gear up to 7000? That seems a long way a way from 6300.
I told him it has been ported to flow 290cc per runner. It just seemed like when I was asking him specific questions all he was doing was plugging it into their program and seeing what happened...
What other company can I call for a second opinion?
236/242 duration will only really change to 238/244 when you go to 1.6 rr's I think. The rr's effectively change the lift, not so much the duration.
210 comp port should do the job ifits 7k max get the best head for the build now and it will run right
If I were running a motor up to 7 and holding it there or close I wouldnt even bother with a hydraulic put a solid in there and really make some power. no risk of lifters pumping up and hurting things. with a qualtiy rocker setup youll only have to ck lash 1 or 2 x a yr if that. where do you want your power to start and stop, gear ratio?
sounds to me like he punched in stealth ram and thats what the computer told him,
what computer setup are you going to run it ? dont forget that if you go crazy with the cam its going to be difficult to tune an efi,
I would find the people on here who have stealth ram setups or have built them and ask them what sort of cam to use, you will probably get better info on CF.
C4 of Year Winner (appearance mods) 2019
BJankuski (Brian) has experience with the Stealth Ram and high HP cars. He has several. Consider asking him about the USR SRam too.
Cuisinart also knows his stuff. For 7k rpm, solid roller sounds the way to go. Shaft rockers I'm guessing too.
6" rods make more top-end power so that's what you want. They aren't any less reliable.
Consider oiling and windage tray with your build.
Bullet cams will work with you to determine a custom cam.
For 7000rpm, you are talking about a race motor and you don't need the extra weight of hydraulic rollers. One thing that hasn't been asked is what your compression ratio is. That has a lot to do with cam selection. A 383 is inherently a torquer motor based on it's bore/stroke ratio. If you are looking for high rpm horsepower, a 377 would fit your needs better.
All things I told to the guy when he made the recommendation... hmm.
Problem is I already have a set of 1.6 roller rockers crane golds. I need to use them to be able to spend all I can on the bottom end. The competition afr 210 or 220 will be good flow and feed it. Only thing I was thinking is upgrading the springs to handle over .600 lift.
Compression: shooting for 10.5:1 still run 93 octane
ecu: holley commander
bosch III injectors 40lb
Ill go with 6" rods (just always heard its tough on cylinder walls)
Rear gear is 3.73 6-speed zf6 black tag, spec flywheel/clutch 2+
usm holley stealth ram ported and cut to fit under hood
Already have remote oil cooler and canton rr pan.
cam is what is in the air
I already have a summit block 1 piece rms fit for hydraulic cam. Everyone ive talked to so far says I dont need flat tappet and should be fine for hydraulic. I need to hold up to 7k but just get there. Not pull. If I make peak power at 6500 I think with a good cam and stable valve train and balanced block shouldnt be a problem. I dont need it all the time, just in certain instances.
I'm no expert but,
I think you got it backwards, short rods should induce more side loading - scuffing of cylinder walls. That's why the 400 cu in small blocks wore out so fast (relatively) was the 5.565" rod with a 3.75 stroke.
Does anyone find it curious (besides me) that AFR recommends a dual pattern cam? I mean: AFR has some of the best I/E flow rates in the industry (upper 70% - 80% I/E ratio), his exhaust will be full competition (so no restriction there), why go big on exhaust duration? (and give up that mid-range pull)
Good point here. Most dual pattern cams favor the intake with increased duration. Exhaust gasses pretty much explode out the port and don't need as much time to exhaust as the intake needs to suck in the charge. Also, that cam is recommended for a 9.0 compression ratio. 10.5 is quite a difference.
Dual pattern SBC cams usually have a longer duration on the exhaust side. ie... 224,230 230,236 236,242
I pmed bjankuski but no response yet. What should be my next move? Should I call comp cams again and try to get someone else? Or try a different company? Or make a new post called "need cam recommendation"? Last thing I want to do is leave power and rpms on the table.
Usually people end up regretting an aggressive cam because they loose drivability and low end torque. Both of which I have no use for. I need this thing to pull hard to 6500 and then not be under 250hp by 7000.
Ive seen some third gen guys slap stealth rams on and get some very unimpressive numbers with inadequate cam and 190cc heads. Making me worried. I would be satisfied with 400 to the wheels but nothing less.
Correct...but either choice of rod length had newer options to mitigate cylinder wall wear. I stuck with 5.7" rods and 383 for torque. But, I went with thinner rings to mitigate cylinder wall wear. IIRC, you can find ring-packs as thin as 1mm,1mm,3mm sets. This is one of the BIG reasons newer blocks regularly go north of 200k miles since the mid-to-late 90's.
Do you mean Comp? I don't see a recommendation from AFR on cam selection. Tests I've read over the years point to anything from a single-pattern cam to 4-degree split for AFR stuff. Not going to be a huge difference either way. Size/config of exhaust matters a bit. Even intake runner length could affect the selection.
One reason I suggested talking to Brian about the USR HSR is power limitations. I think he had some frustrations and had to rework it quite a bit. I also wonder if he thinks a MR would be better for your power range? I was thinking the HSR was better for a 6200-6500 RPM setup.
some good points here. You can run a single pattern cam with the afrs but running a split pattern can carry the power a little farther up. At that point its all about valve opening and closing events. You can have your cake and eat it too without blowing all your torque out the exhaust.
Try getting ahold of someone like Mamo, Chris Straub or the likes for the the "right" cam. Comp tech guys can only spend so much time
Im thinking there are some good off the shelf cams that will work fine just geting the right one. only about a bazillion cams have been ground for the sbc.
Sounds lke youre stuck on a HR...if you did go solid know most co's are making bushed rollersnow so no needle bearings to go bad couple that with a ramp that isnt too "extreme" you should have long life with either type of cam
Its not that im stuck on the hsr, its more that is what I have. It would tack another $1000 on the price tag for a miniram. Im already over budget because I sprang for the afr heads. I know I could sell the hsr for some but thats not cash in hand. I would rather spec a cam with some growing room in it and swap later than sacrifice my rpm.
I hope I can speak to brian soon. Im about to have to order parts and get this thing started or it wont be done by aug when I have to go back to work.
