marker lights-1993
Old Jul 1, 2014 | 10:20 PM
nebraska93's Avatar
nebraska93
6th Gear
Default marker lights-1993
I have not be able to get any (4 corners) of my side marker lights to work (1156 bulb), the small ones (24 bulb) works fine. These lights should come on anytime the lights are on right? I've changed both the sockets and bulbs on the front, haven't got to the back yet. Checked power up front but have none on the red wire, any other option other than back probing the wire.
Old Jul 2, 2014 | 12:50 AM
Hooked on Vettes's Avatar
Hooked on Vettes
1156 Bulbs are for the front Cornering lights.
They stay on solid when the turn signal switch is on for that side.
The Headlight switch must be in Head or Park.
Old Jul 2, 2014 | 09:17 AM
nebraska93's Avatar
nebraska93
6th Gear
I checked this morning and when the front turn signal is on the only one flashing on the side is the small #24 bulb, no #1156. On the rear nothing is flashing so I need to get under there and replace both #24 and #1156 bulbs. They will probably be like the front ones, all crusted in the socket and the lamps were cloudy and came apart when I tried to remove them. I needed something to do this weekend anyway, can't drink beer all weekend. Wait what am I saying! thanks
Old Jul 2, 2014 | 10:58 AM
Hooked on Vettes
Here's all the schematics you need.
1) Cornering lamps
2) Backup lamps
3) Front parking, turn signal and side makers
4) Rear turn signal parking lamps and side marker
Old Jul 2, 2014 | 05:23 PM
nebraska93's Avatar
nebraska93
6th Gear
I'll get on it, thanks.
Old Jul 2, 2014 | 05:41 PM
WVZR-1's Avatar
WVZR-1
First check for he "rear corners" is simple. Do your back-up lamps work? If NOT then there's no need to rip into the corners first.
To marker lights-1993
