Spec Clutch
Old Jul 2, 2014 | 02:15 PM
Timo's Avatar
Timo
Default Spec Clutch
Hello ! I have a '95 Vette 6-speed. Centerforce Dual Friction clutch is slipping. Spec Clutch offer seven stages ( 1,2,2+,3,3+,4 and 5 ). Which stage is a right choice for me. Power of motor is 500+ hp /500+ lb-ft. ( Procharger ). I drive on the street and tires are normal street tires.
Timo
Old Jul 2, 2014 | 02:33 PM
Race Prepared's Avatar
Race Prepared
3 or 3+
Old Jul 2, 2014 | 11:42 PM
FrankieD's Avatar
FrankieD
Spec 3+ And when you get it you would wonder how you managed before without it.
Old Jul 3, 2014 | 09:34 PM
dizwiz24's Avatar
dizwiz24
Ditto on the 3+, this is what i run on a similarly powered procharged 93.
Also, might want to do the zfdoc trans countershaft shim mod (ie. Slightly thicker shim ipo of the stock one) while you are in there.
This cut down on gear noise a lot, even with my lightweight alum flywheel.
To Spec Clutch
