My '84 Has Issues :(
Old Jul 6, 2014 | 12:08 PM
Charlene Castle D's Avatar
Charlene Castle D
2nd Gear
Default My '84 Has Issues :(
Hi guys......need your assistance please:
My '84 C4 crapped out yesterday.......check engine came on and it lost all compression and died. It started back up but didn't stay running. The spark plugs were bad so all have been replaced, along with new wires. Also replaced was the coil, cap and rotor (components inside were cracked/burnt) and the fuel filter. Injectors seem ok. Car still starts up but dies out after a few seconds.
Help, has anyone had this issue?? Thank you so much!!!!!
Old Jul 6, 2014 | 12:54 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Put a fuel pressure gauge on it...see what your pressure is. Spec is 9-13, but what ever number you see, it shouldn't drop or change under any circumstance. Report back.
Old Jul 6, 2014 | 01:54 PM
Charlene Castle D
2nd Gear
Thank you! I will need to get it into the shop for that right?
Old Jul 6, 2014 | 08:54 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Depends on your abilities,but it's not hard; buy/borrow a gauge, "T" into the rubber line between the engine and frame.
To My '84 Has Issues :(
