When does the ECM go into open loop???
Old Jul 24, 2002 | 06:12 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default When does the ECM go into open loop???
Is it at 100% TPS??? I am just starting to delve into this, and did a quick little test run after I got my ALDL cable working.. my car doesnt seem to go into open look at 100%TPS however.. I was only at 100% very briefly, so that may have something to do with it too. (gonna be LOTS of questions from me over the next few days! ;) )
-Mark
Old Jul 25, 2002 | 12:38 AM
h rocks's Avatar
h rocks
Default Re: When does the ECM go into open loop??? (MarkLT1)
Mark, to state the obvious, the computer starts off in open loop. After the O2 tells the computer that it's warmed up, then it's in closed loop adjusts the the AFR to as close to stoich as possible.
Old Jul 25, 2002 | 01:02 AM
Hendej's Avatar
Hendej
Read the PCM tutorial here:
http://para.noid.org/~lj/
Has a good explanation of LT1 open loop vs closed loop. Nice 9" Camaro, too.
Old Jul 26, 2002 | 10:00 AM
Carl90's Avatar
Carl90
I was confused on this topic, too. There is some misleading literature out there that says that says that at Wide Open Throttle (WOT) the engine goes into Open Loop. 100%TPS would certainly be WOT. Actually, the ECM goes into Power Enrichment (PE) mode, which I believe is similar to Open Loop (no feedback from the O2 sensor is used). Do not know about other years, but for my ECM there are separate tables for Open Loop and PE.
I am still in the Blockhead Learning Mode (BLM), so confirm for yourself :)
Carl
Old Jul 26, 2002 | 11:27 AM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Re: When does the ECM go into open loop??? (Carl90)
Carl
That makes sense, and yes, I think I have PE tables.. thanks for clarifying!
-Mark
To When does the ECM go into open loop???
