X Brace under car
Old Jul 7, 2014 | 08:48 AM
gapretzel's Avatar
gapretzel
Default X Brace under car
found my 88 vert has an x under it. Goes from front drive tire to rear passenger tire and opposite on the other side It appears to be some sort of cross brace. Looks like it will need to be dropped before I can drop my trans pan. Any comments or suggestions?
Old Jul 7, 2014 | 09:32 AM
c4cruiser's Avatar
c4cruiser
Not a big deal to remove but the higher you can get the car, the better. Each corner has two bolts and there are nuts to remove on each side of the back half of the brace. You can use a floor jack under the center of the brace to lower it and also to raise it back up when re-installing.
The brace is not real heavy but just bulky. The bolts are torqued to something like 47 ft-lbs and the nuts to 20 ft-lbs.
Old Jul 7, 2014 | 04:32 PM
gman35's Avatar
gman35
post pics of that x brace.. on the car.. would be nice for reference.. thanks, gary
Old Jul 7, 2014 | 05:58 PM
gapretzel's Avatar
gapretzel
will try to get some pics up tomorrow or wed. Anybody know what they are far?
Old Jul 7, 2014 | 06:39 PM
ex-x-fire's Avatar
ex-x-fire
It helps stiffen up the unibody. Coupes could use these too.
Old Jul 7, 2014 | 07:30 PM
PcolaPaul's Avatar
PcolaPaul
I think all the verts have an X-brace for rigidity. I could be wrong.
Old Jul 7, 2014 | 09:06 PM
c4cruiser's Avatar
c4cruiser
All of the C4 convertibles came with the underbody X-brace. But one thing to consider when adding it to a coupe is that some of the holes and weld nuts are not present in the coupe frame. The coupes don't have the studs in the belly pad either.
Also, the factory ride height of the convertible is slightly higher compared to that of the coupe. That's necessary because the X-brace takes up about 1-1/4" of space under the car.
Old Jul 8, 2014 | 08:34 AM
gapretzel's Avatar
gapretzel
Had to post picture as attachmentName:  DSC_0042.jpg
Hope it is visible. This was best I could get as I had it on the ramps to change oil.
Thanks for the help
Old Jul 8, 2014 | 05:38 PM
Race Prepared's Avatar
Race Prepared
Correct!
To X Brace under car
