Coolant in Air Filter Housing
when you shut down the cooling system is still pressurized for several hours and a tiny leak in the TB coolant passage could dribble a 1/2 cup down into the filter as the pressure forced liquid out of the TB and into the accordion to the filter.
If there is no coolant on the ground after letting it cool off, that has to be it. If it were an external leak that happened to spray at the filter, then it would have some evidence on the ground as well...
Next question....does the air filter show signs of coolant hitting it or is it dry and clean?
He was not a "car-guy" so I hustled down to take a look. Sure enough the air filter was saturated. Seems the fuel pressure regulator diaphragm had ruptured and was sending fuel back up the vacuum line to the manifold and down the intake tube. And yes that raw gas went through the MAF sensor (which survived), but it certainly gave new meaning to the term "burn off module".
just 'cause its not normal don't mean it can't happen !
Like the 1st time I saw my engine running and spraying RAW Gas out of the exhaust !
besides being scared spitless
( all I could think of was BOOM !)
....the question of how in the hell can this happen, started to echo in the vast emptiness aka my head.
(answer to the quiz, batch-fired fuel injectors and ONE shorted to ground thus shorting that bank and sticking them ALL WFO instead of any kind of duty cycle) It gushed gas into the rt bank WITH the left bank doing all the work and running the engine !That alone was a BIG surprise.
God only knows how close it came to hydro'ng each of those 4 cylinders !
That sucked several GALLONS in just a couple minutes, with about 2 gal in the crankcase.
The rest went out the tail pipe.Strange butt true....
