Non functioning power antenna '87 ragtop
Old Jul 10, 2014 | 01:35 PM
gergstuff's Avatar
gergstuff
Default Non functioning power antenna '87 ragtop
I searched the forums and found many with similar power antenna problems. I would like to check the relay and I see many references to where the relay is located for the coupe but not the convertible.
Can someone steer me in the right direction?
Thanks,
Craig
Old Jul 10, 2014 | 04:31 PM
Hooked on Vettes's Avatar
Hooked on Vettes
The antenna relay is located inside the car above the driver side wheel well housing.
Probably under the carpet.
Old Jul 10, 2014 | 11:34 PM
gerardvg's Avatar
gerardvg
As the previous poster mentioned check you have power, the antenna will not work if the grease has all dried up.
Remove the antenna and drill the rivits holding the plastic case together, remove the clips and pull it appart.
If the antenna cable has broken replace that, if the grease is gone grease the gear and the wheel assembly the antenna cable goes into so it doesnt jam on the antenna plastic case.
Reassemble and replace the rivits with a bolt and nut.
Old Jul 11, 2014 | 09:26 AM
beerme's Avatar
beerme
My 87 vert antenna wouldn't shut off a couple months ago when I parked the car. I reached behind the drivers seat in the rear compartment and pulled the carpet back and found two electrical connectors. I simply follow the wires with my hands to the antenna and unplugged that connector and the it cut power to the antenna.
I suspect my antenna motor gear is stripped as the antenna wasn't going up or down. I just put the antenna up about 6 inches and have left it as is....
The connectors are not hard to find, but they are very hard to actually see. Alot of hand work and judgement by feel is what I did it.
best o luck,
Old Jul 11, 2014 | 09:58 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
On my '88, for a convert., the Antenna Relay is located: "LH side of cargo compartment, above rear of wheelhouse".
Old Jul 11, 2014 | 02:04 PM
gergstuff's Avatar
gergstuff
I found it, it was on the drivers side attached to the underside of the back deck, needed the tonneau cover open and to keep the back of the convertible top up to see it. I will have to get my 12 year old to crawl in there and get it out for me.
To Non functioning power antenna '87 ragtop
