Changing Oil Pressure Sending Unit/switch
Old Jul 11, 2014 | 10:31 AM
buktlst's Avatar
buktlst
Default Changing Oil Pressure Sending Unit/switch
Have a oil leak found out it is my oil pressure sending unit/switch by the distributor. Is it a pain to change them? Never replaced one before
Old Jul 11, 2014 | 11:20 AM
John A. Marker's Avatar
John A. Marker
Yes, they are a PITA. Best way is to pull the distributor. I would line up the timing marks and record the position of the rotor before pulling the distributor.
Old Jul 11, 2014 | 11:28 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I also record (mark) the position of the rotor just after the dist is raised up for a good starting index when inserting.
I use a non-hardening Permatex on the threads when installing those units.
Old Jul 12, 2014 | 12:23 PM
Deepa's Avatar
Deepa
http://www.autozone.com/autozone/acc...er=141490_0_0_
I was able to do this from the drivers side without pulling anything. This socket and a 12" extension did the trick.
Mike
To Changing Oil Pressure Sending Unit/switch
