I need to wire in my boost gauge and wide band however I do not have a clue where i should wire in to the car. Does anyone have images on where they wired in these gauges.
When I wired in my wide band A/F gauge I removed the panel over the shifter in the center console and found a switched wire to run both the gauge and the heater for the 02 I can't remember which wire it was but with a simple tester you can tell which one it is, on my 93 it was very easy to find. I mounted the gauge in the dash just below the radio. Good luck.
Did you drill a hole in the the tunnel to run the wires or did you run it through an existing hole to wire in the O2 sensor
Has anyone wired a innovative wide band I am baffled how this wires in i have the sensor run however the instructions are telling me to connect certain wires to my gauge that do not exist. .... I am totally lost
I figured it out. I think I may have been too tired and stressed out. .. I ran the switched on power from the fuse block and grabbed a ground from the cigarette lighter.
