Bad FPR Diaphragm
Old Jul 19, 2014 | 03:47 PM
C4ProjectCar's Avatar
C4ProjectCar
Default Bad FPR Diaphragm
I tested my fuel pressure, and with key on but engine off it would go to 42, then drop about 1 PSI every 2 seconds. I pulled the vacuum tube on the FPR (just to be sure, the vacuum tube is the thin tube that comes off the FPR in the direction of the passenger seat, right?), and gas poured out of it. Since this shows that my FPR diaphragm is bad, I plan on buying this replacement diaphragm and replacing it. Since gas has been sucked through the vacuum line, does anything else need to be done?
Old Jul 19, 2014 | 04:47 PM
C4ProjectCar
So, it looks like my engine is hydrolocked from gas getting sucked through the vacuum line into the intake manifolds, then draining into the cylinders. I read that this causes gas to get into the oil, necessitating one or two oil changes to get the gas out of the system.
Here's the plan:
Replace the FPR diaphragm.
Pull the plugs, disconnect the coil, and turn over the engine a few times to get the gas out of the cylinders.
Change the oil with some cheap oil, run the engine a while to circulate the oil, then change oil again with some decent oil to keep in there.
Old Jul 19, 2014 | 05:15 PM
Bandit's C4's Avatar
Bandit's C4
Central PA Events Coordinator
St. Jude Donor '12-'13
Would it hurt anything ... by removing ALL the spark plugs and allowing the present gasoline to evaporate away over time?
Old Jul 19, 2014 | 05:48 PM
C4ProjectCar
You mean just leave it with the plugs out instead of cranking the starter? I suppose I could do that, but I'm not sure what the point would be. Is there an advantage to doing it that way?
Old Jul 19, 2014 | 06:51 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
It would let excess fuel evap instead of further washing the cylinder walls...IF there is excess fuel in the cylinders. Though some may have past the rings I should think most would have blown out the exhaust port.
Are you sure excess gas has gotten into the cylinders?? Pull a few plugs to see if there is excessive gas smell.
Old Jul 20, 2014 | 12:53 AM
C4ProjectCar
I pulled all of the plugs, but the engine wouldn't turn over (either the starter is bad or a ground isn't connected well) so I'm just letting it sit.
There must have been gas in the cylinders, because it was dripping gas after I pulled them.
To Bad FPR Diaphragm
