still vibrates
Old Jul 22, 2014 | 10:09 PM
shawnsdad's Avatar
shawnsdad
Default still vibrates
still getting vibes through the steering wheel.. everything is tight that i can see. vibes under acceleration and shakes bad when hard braking. whats funny is it shakes and pulls but i get no feed back through the brake pedal from a warped rotor.. tires are balanced and rims are true.. so anywhere else i can look?
Old Jul 22, 2014 | 10:17 PM
DanielRicany's Avatar
DanielRicany
Look for a bad tire and check tire pressure. Also check your brake pads and rotors and make sure they are good. You should check the runout on the rotor and wheel hub on the front wheels and make sure they are within spec.
Old Jul 22, 2014 | 10:21 PM
shawnsdad's Avatar
shawnsdad
tire pressure is perfect. tires are perfect.... i know it needs rotors and brakes. they are ordered. how do I check hub?
Old Jul 23, 2014 | 09:22 AM
senorv47's Avatar
senorv47
Your Rotor are probably warped, change them out and you will see the difference.
Old Jul 23, 2014 | 12:47 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
It is important to properly torque the lug nuts to prevent rotor runout
After servicing your brakes, torque all to 100 FtLbs
Retorque after the next 50-100 miles.
Old Jul 24, 2014 | 12:29 AM
DanZ51's Avatar
DanZ51
All of the above and find a garage that can do "road force balancing"
http://www.gsp9700.com/
To still vibrates
