C4 Overheating
Old Jul 23, 2014 | 02:49 AM
Southsaturn's Avatar
Southsaturn
3rd Gear
Default C4 Overheating
I decided to take my Corvette up to the mountains in Big Bear. It was a hot day about 105 degrees. The car ran fine until we start climbing the mountain. The temperature start going up quickly and about half way up I had to pull off when the temperature reached 260 degrees.
I waited about an hour turnaround and went back down the mountain. Car stayed cool and was cool all the way home about 30 miles away. Highest the temp went on the way home was 205 and that was only for a minute before settling around 200.
I have been testing the car since to see if it will overheat and it hasn't since. stays between 190 and 200. I driven on the freeway and in traffic no problem. I let it idle in my garage and it stays about 205 - 210. Never gets hot.
Anybody have any idea whats the problem?
Old Jul 23, 2014 | 05:39 AM
mcm95403's Avatar
mcm95403
If you let it get that hot you probably just toasted your rings - especially if you pulled over and just let it soak at that temperature. You'll know in a couple thousand more miles if you oil gets black much faster than normal and starts blowing out the dipstick - guess how I know.
The radiator should be pulled and the front cleaned. A better water pump (Stewart) won't hurt, and you might as well put in a new 195 thermostat in while you're in there.
Good luck and hopefully you won't be putting an engine into this winter.
Old Jul 23, 2014 | 09:30 AM
gerardvg's Avatar
gerardvg
Hi
As mentioned by MCM check the gap between the a/c condenser and radiator, you will need to remove the cover (heaps of bolts) to access the gap.
There will be leaves, twigs, small roadkill, plastic bags and so on trapped in there, once cleaned out fit some mesh to keep it clean.
http://www.ebay.com/itm/360251155164...84.m1438.l2649
http://www.ebay.com/itm/84-91-CORVETTE-C4-ALUMINUM-MESH-RADIATOR-SCREEN-NEW-/290401657970?pt=Motors_Car_Truck_Parts_Accessories&hash=item439d49a472
Old Jul 23, 2014 | 12:12 PM
BBNJKen's Avatar
BBNJKen
Originally Posted by gerardvg
Hi
84 91 Corvette C4 Aluminum Mesh Radiator Screen New | eBay
Wow, $45... I went to H/D and bought an expanded metal gutter guard for ~$3, and the local Autozone for 2 pkges of license plate mtg hardware & installed. Ttl cost around $13.
Old Jul 23, 2014 | 12:44 PM
scotth48's Avatar
scotth48
I bought two piece's of expanded metal at Lowe's to make one, but changed my mind, because it being expanded metal with a ruff surface that debris would stick to it and not fall off. I than bought some perforated stainless, but nosy afraid the holes are not big enough to let air to flow through, so going to leave it as it was. Hopeful the new DeWitt's will help and cleaning once in a while will suffice.
Old Jul 23, 2014 | 01:07 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Mine has seen temps higher than that before I learned about burbing the cooling system. Still running fine after all these years.
Old Jul 24, 2014 | 12:01 AM
Southsaturn
3rd Gear
Thanks for the info. I will try removing the shroud and cleaning it out.
Old Jul 24, 2014 | 11:23 AM
scotth48's Avatar
scotth48
Old Jul 24, 2014 | 11:32 AM
MZee's Avatar
MZee
Originally Posted by scotth48
I have it too. but it only gets to 3/4 of the way to 260. Idling in traffic on hot days, otherwise it's fine.
M
Old Jul 24, 2014 | 11:42 AM
markKlein's Avatar
markKlein
M
Sounds like you are looking at the analog gauge. That can be deceiving, better to check the digital.
Old Jul 24, 2014 | 01:05 PM
scotth48's Avatar
scotth48
I guess we have to trust the digital gauge for water and oil temperature and the analog gauge for oil pressure!
Old Jul 24, 2014 | 01:17 PM
GKK's Avatar
GKK
It takes A Lot more than one occasion at 260* to toast the rings...
If you fried the rings at 260*, your engine was long abused beforehand...Probably, very little maintenance and regular oil changes...
Old Jul 26, 2014 | 02:48 PM
frosted's Avatar
frosted
I'd make sure both fans turn on all the time. I had a primary fan that would turn on 90% of the time but not always. After being really confused why I was reaching 260, I finally figured it out by testing multiple times from the ALDL connector. Secondary fan was burning it's fuse all the time. Rotating the fans by hand, both felt fine. It was only after I had removed one fan motor and compared it with a new motor that I understood how bad the originals were.
Old Jan 10, 2015 | 05:16 PM
ETM's Avatar
ETM
I have a `95 Auto with about 87k on it. My car isn`t overheating. It runs normal temp around town in stop and go traffic. Fans are coming on and it stays in normal parameters.
The concern I have is that it is running hotter than it should on the freeway. The temp {both gauges} goes up at speed. It had been running about 209-215 for awhile when I took it the freeway. Actually got as hot as 219 last week.
It seems to actually cool some when I get off and running at lower speeds. So the car isn`t technically overheating but something is off.
Any help would be appreciated.
Old Jan 10, 2015 | 06:44 PM
don hall's Avatar
don hall
Originally Posted by ETM
......The temp {both gauges} goes up at speed. It had been running about 209-215 for awhile when I took it the freeway. Actually got as hot as 219 last week.
Probably should have started a new thread, but maybe we can help.
Since temps are running normal at low speeds (fans), it would follow that the reason the temp increases on the highway might be due to the blockage of air flow behind the radiator, or damage to the air dams preventing upward airflow. A t-stat that only opens partially will cause temps to rise at highway speeds.
Cooling is basic..... air flow, coolant flow.... block one, or both, and
you will overheat.
Old Jan 10, 2015 | 08:13 PM
ETM's Avatar
ETM
Thanks.
That is what I was leaning towards. I have had the buildup of dirt, leaves etc blocking the radiator in the past. It looks pretty clear from what I can see. One other thing that I noticed is that the car seems to get up in temp{into the 200s} really fast from startup. Does that point to the TStat as well?
Old Jan 10, 2015 | 08:26 PM
Southsaturn
3rd Gear
My problem turned about to be like everyone said, a lot of leaves and stuff blocking the airflow. I replaced the radiator since I had to take it apart and installed a new Thermostat and it runs fine. It stays in the mid to high 180's and never hits 200. I would say airflow blockage is your problem.
To C4 Overheating
Old Jan 10, 2015 | 09:11 PM
don hall's Avatar
don hall
....one thing that I noticed is that the car seems to get up in temp{into the 200s} really fast from startup. Does that point to the TStat as well?
Certainly...... if you need proof.... pull the t-stat, place it in boiling water with an industrial thermometer,
and check for the opening temp. T-stats are relatively cheap, if it has not been changed for some time.
replace it, even if it checks out 'good'.
Old Jan 12, 2015 | 07:51 PM
ETM's Avatar
ETM
Thanks for the help fellas.
Turns out the radiator was toast. I`m fairly certain it`s the original which would make it about 20 years old. Not bad service.
Old Jan 12, 2015 | 07:55 PM
don hall's Avatar
don hall
At least you discovered the problem. Thanks for posting the solution.
