I'm having a new chip burnt a new chip for a larger cam on my 1987 coupe.
Should I delete VATS even though it has never failed me? From what I've read this is a real PITA when it does fail.
(The car is hardly parked outside and people ignore car alarms anyway)
If your having a chip burnt, it's very easy for the tuner to shut the vats off in the chip..After having that done you still have to do the vats ignition cylinder bypass and cut and splice the wires in the Starter enable relay to bypass that... The problem is, your car is valnerable to theft from that point on if left outside unattended..... ..If your going to do it , below is a site with the proper instructions.....WW
Programming it out only stops the ecm from needing authorization to pulse the injectors. As has been said the starter enable relay still needs to be dealt with for a full bypass. I remove it for most chips I do, and if they're speed density it is because I run them in mine first before being sent out.
Darn, I disabled VATS it on my last chip burn but everything is still intact.
Is the major failure with the relay or with the contacts in the steering column that reads the resistor on the key? Hmmmm....
James
There are more problems with the ignition cylinder reading the keys then with any of the other operations...When the key can't be read, it shuts the car down..Once in a great while you will hear of a "starter enable relay" going bad , but not to often....WW
I deleted VATS and pray my car gets stolen. I leave it running and go inside to shop. No takers yet.
Im sure if a car thief had his choice, he would pick a newer car like a Honda Accord over our C4s... Also C4s stand out in the crowd, since there not seen on the road as often as newer cars... A cop could spot them to easy...Looks like you may have to run your car off a cliff to get paid.........WW
I am also considering deleting VATS. The only problem with it on my 93' is FEDS. I shut it off and it wont start again. This problem has gradually gotten worse. I have checked all the grounds all door switches. I don't want to tear into the dash and look for a bad connection. Any suggestions? Can you just delete FEDS?
I hope you guys got a laugh ! I can honestly say I drive my car now without any concern over the $20K I have spent on it. Which brings up a point I would like to make regarding a money pit. If I get 1 year out of the car it is worth $3000 a year to me. In other words if I can drive my C4 and enjoy it for 4 or 5 years then no regrets. I deleted the VATS to avoid any problems from it. I had done the key bypass shortly after buying the car. It left me stranded a few times too many. When you are sitting in the drivers seat and your woman is looking at you like this car sucks it motivates you to delete the VATS.
