Anti-sway bar replacement when doing rear monospring?
Well, looks like I'm going to have to replace my rear monospring, which is starting to delaminate. Luckily I live in St. Petersburg and can drive over to Vette Brakes and pick one up over the counter. I've had a recommendation that I do the rear anti-sway bar at the same time. I wouldn't mind, but it does look like a little bit more work. According to my GM service manual you've got to pull off the mufflers to get the bar out and the new one in.
Any opinions on this? Should I spend the extra $100 on the bar (the monospring plus new hardware is $300). Anyone replaced one and can give me a handle on how much work it is? If I do it, should I go with the polyurethane or rubber bushings?
As always, any advice and opinions are appreciated.
Re: Anti-sway bar replacement when doing rear monospring? (Tom Mieczkowski)
After reading your post,Is there a reason you want or need to replace the bar? IS it too small or something else wrong with it?
It was sounding like you were being given advice to change it out for some reason but I dont know why.Is your car not handling the way it should be?
What size is the new bar over your stock one?
Just wondering..sorry for the questions but dont want to see someone replace stuff they dont need to due to some advice they got somewhere but yet there isnt anything wrong with their current set up.
_Brian
Re: Anti-sway bar replacement when doing rear monospring? (BrianS)
I looked over the procedure in a haynes manual and it does not mention taking out the mufflers. Are you sure this is necessary?
_Brian
_Brian
Eric
Well, looks like I'm going to have to replace my rear monospring, which is starting to delaminate. Luckily I live in St. Petersburg and can drive over to Vette Brakes and pick one up over the counter....
For the swaybars, it's the same thing. The front and rear bars need to be paired. I wouldn't run a stiff rear and soft front.
BTW, to convert Hib's suspension chart from metric spring rates (Newtons/mm) to English (pounds/inch) divide by 0.17.
Eric
Eric
Re: Anti-sway bar replacement when doing rear monospring? (silver & red CE)
I replaced my rear sway bar with a larger one. I did not pull the mufflers, but I did have to pull the spare tire. The rear is not real easy, but If you are mechanical enough to replace the spring then you can do the bar with no problems.
