Fuel Pressure
I have a 1990 L98, highly modified six speed C4.
Mods:
Motor is a 383, with AFR 195 (Eliminator) Heads, 10 to 1 compression ratio, Modified HSR manifold (fits under the hood), BBK 52mm Throttle-Body, LT4 Hotcam, Full length headers, no CATS, true dual exhaust, FAST XFI 2.0 with Dan White Adaptor harness (BTW: Dan is a great guy to deal with), and 32lb Bosch-3 fuel injectors with a new C4 stock fuel pump.
Currently I am set to 44 psi. Any ideas, Thanks.....
Some people will recommend using higher pressure but keep in mind as fuel pressure goes up, fuel flow (in gallons per hour) drops,
Also look up the duty cycle of injectors, its never a good idea to bump up the pressure too high and work the injector too much.
The car will run rich at idle with 48/50 psi fuel pressure however you get more mid range and top end go with more fuel pressure.
My bosch 111 injectors have no problem with up to 75 psi fuel pressure, that is variable in relation to boost.
I am running a blower and have a vortec FMU that pretty much restricts the fuel return to the tank, to raise fuel pressure and force more fuel thru the injectors at around 5 psi per psi boost.
That works great with more standard fuel pressure at idle and way more at higher rpm so it never leans out in my application.
