Which scan tool to buy?
Old Jul 26, 2002 | 12:48 PM
lead_foot's Avatar
lead_foot
Default Which scan tool to buy?
I have a 96 LT4, so I want to be able to easily read OBD II codes and check sensors. The Auto Xray seems to be a popular tool. They have an OBD II Scanner for $290 or the EZ-Link Diagnostic Scanner Kit for $390. I want to be able to use it on my 89 Firebird which is OBD I. So I'm assuming that the Kit is what I will need.
Do you experienced folks have any suggestions? I don't own a laptop.
Old Jul 26, 2002 | 12:57 PM
vettmech's Avatar
vettmech
Default Re: Which scan tool to buy? (lead_foot)
Buy a Tech I .......it's what the GM techs use and NAPA sells them but you'll have to order it............ and I think they aren't cheap
Old Jul 26, 2002 | 03:48 PM
ConeKLR's Avatar
ConeKLR
Cruise-In II Veteran
Default Re: Which scan tool to buy? (vettmech)
:lol: Tech 1... get ready to sell one of your kids if you have any. You'll need the extra money. :yesnod:
Old Jul 26, 2002 | 03:50 PM
ConeKLR's Avatar
ConeKLR
you should also try this question over in the ECM section :yesnod:
Old Jul 26, 2002 | 05:20 PM
lead_foot's Avatar
lead_foot
Default Re: Which scan tool to buy? (ConeKLR)
I posted it over there too. No responses yet.
Old Jul 26, 2002 | 05:32 PM
Guest
Guest
Posts: n/a
I went the Autoxray route then due to my chip programming right now found I really needed Diacom and bought it.
The AutoXray is a fair unit, pretty easy to use but no trending ability. Diacom is only $260 but you need a cheap laptop for it. The difference is night and day between frame scanners and realtime like Diacom.
HTH
Old Jul 26, 2002 | 08:42 PM
04Z16's Avatar
04Z16
CI 3-4-5-6-7-8-9-10 Veteran
I've got the auto xray and bought it from a place in washington state here is the site http://www.autotestsys.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=ATS&C ategory_Code=AX . I think I had the unit in about three days. I does all I need to do and it does real time for 29 seconds to capture problems like drivability issues. Works well.
Old Jul 27, 2002 | 08:29 AM
93 ragtop's Avatar
93 ragtop
Default Re: Which scan tool to buy? (GS487)
I have the auto x-ray pro pack. I think it was $399.00 from summit. The nice thing about it is it will do ODB II or I, chrysler, ford, and several of the foreign vehicles. IMO the biggest problem with all of the scanners is they give you the data, but it is up to you to interpit it. IE: is 870mv. reading from a o2 sensor good? What should it be? You are going to have to spend some time reading and studying the system on a car and get a good understanding of it in order to fix it or for that matter to decide if it is even malfunctioning. Now this is where I am having problems!! Good luck with your decision.
Old Jul 27, 2002 | 08:51 AM
MagRed_04's Avatar
MagRed_04
Default Re: Which scan tool to buy? (Red 86 4+3)
I have the Auto X-ray and it works fine for me!!! :D
To Which scan tool to buy?
