Non-corvette Dana 44 gear sets?
Old Aug 2, 2014 | 10:15 AM
jv9999's Avatar
jv9999
Default Non-corvette Dana 44 gear sets?
Is there anything unique about the Vette Dana 44 gear set? Do others such as Jeep ones fit the carrier?
Just curious
Old Aug 2, 2014 | 11:00 AM
WVZR-1's Avatar
WVZR-1
Just curious
A correct gear set requires the D44HD gear sets. A D44 can be used with sleeves and appropriate bearings BUT the pinion shaft is of less diameter. The D44HD is done in a couple different variations and NOT all can be used but if it's advertised as D44HD with 3/8" hardware it's likely a fit. If you see D44 -Vette/Viper it can be considered a fit with maybe doing some work to use the ring gear as there's 3/8", 7/16" and even 1/2" hardware.
Yes there are Jeep that fit. Not all but there are some.
Old Aug 2, 2014 | 01:13 PM
jv9999's Avatar
jv9999
Originally Posted by WVZR-1
A correct gear set requires the D44HD gear sets. A D44 can be used with sleeves and appropriate bearings BUT the pinion shaft is of less diameter. The D44HD is done in a couple different variations and NOT all can be used but if it's advertised as D44HD with 3/8" hardware it's likely a fit. If you see D44 -Vette/Viper it can be considered a fit with maybe doing some work to use the ring gear as there's 3/8", 7/17" and even 1/2" hardware.
Thanks, that's just what I was looking for.
To Non-corvette Dana 44 gear sets?
