Broken Transmission Cooling Line
Old Aug 4, 2014 | 09:54 PM
krukker76's Avatar
krukker76
Cruising
Default Broken Transmission Cooling Line
Hey guys. So i tried to change my radiator and the transmission line to it twisted and snapped. I have the fittings and i am trying to flare the 5/16 transmission line. It is being a bitch. Do I need special flare tool for this. It just keeps backing out of the vice. I am so confused. Help!
Old Aug 4, 2014 | 10:40 PM
jv9999's Avatar
jv9999
The OEM lines are very hard to flare as they are not meant for hand flaring. Also, I believe they are a double flare. You might have to replace it, or replace part of it and use a compression fitting to join them.
Old Aug 4, 2014 | 10:48 PM
hooked073's Avatar
hooked073
just went thru this trying my hardest not to ruin the line but i did so here is what you need to do. You need to save the factory end if you notice it is long what i did was drill the old like out of the fitting untill it came out not a big deal. Then get a short section of tubbing both ends were already flaired so i cut the line to the length needed fed the line thru and used compression fittings to connect the old to new caake walk
Old Aug 4, 2014 | 11:08 PM
John A. Marker's Avatar
John A. Marker
...go to the hardware store and buy a compression fitting to join the two lines. Much easier to join them together.
Old Aug 5, 2014 | 03:40 PM
krukker76's Avatar
krukker76
Cruising
Default Compression fittings
If I use a compression fitting I still need to flare the ends right?
Old Aug 5, 2014 | 07:31 PM
hooked073's Avatar
hooked073
no you will not need to flair a thing if you do what I said
To Broken Transmission Cooling Line
