Need 160 tsat install help ASAP!
Old Jul 26, 2002 | 07:51 PM
Lone Ranger's Avatar
Lone Ranger
Default Need 160 tsat install help ASAP!
I have the top fitting off the pump and the stock thermo is exposed, but it seems to be in there tight. What is the trick to getting it loose and will the pump gush coolant when the stock tstat is removed? The engine is cold.
Do you just grab it with a pliers and pull 'til it pops out? :confused:
[Modified by Lone Ranger, 5:52 PM 7/26/2002]
Old Jul 26, 2002 | 07:54 PM
STL94LT1's Avatar
STL94LT1
Default Re: Need 160 tsat install help ASAP! (Lone Ranger)
That's what I would do.
Old Jul 26, 2002 | 08:06 PM
Lone Ranger
Default Re: Need 160 tsat install help ASAP! (STL94LT1)
Okay, did that and... it worked! Just a little bit of coolant gushed, not much at all. So far, what little coolant has escaped has gone down the front of the pump and stayed clear of the Opti, but when finished, going to *thoroughly* check and dry, sopp up any I find in front there...
Now to bypass the TB....
Old Jul 26, 2002 | 10:09 PM
Lone Ranger
Phew! Got it all back together, 160 tstat installed, TB coolant bypassed. I had to cut the little elbow TB coolant line off it was welded on pretty good. Typing this while letting the HPP III program the ECM to sync radiator fans to the 160 tstat. :cool:
Test drive pending... :D
To Need 160 tsat install help ASAP!
