Putting in a different Chip...quick question.
Old Jul 27, 2002 | 09:27 AM
HighRev03's Avatar
HighRev03
4th Gear
Default Putting in a different Chip...quick question.
Got my chip today and am getting ready to put her in....just wanted to double check this.
Is it ok to leave the battery connected.....? or should I disconnect the negative terminal...
My helms says....to disconnect....just curious....I would rather keep in connected if its ok...
Like keeping all my presets on the radio....and don't want the computer to have to relearn stuff either...
thanks
Jim
[Modified by rockycamaro, 1:28 PM 7/27/2002]
Old Jul 27, 2002 | 11:46 AM
Triple Black 88's Avatar
Triple Black 88
Default Re: Putting in a different Chip...quick question. (rockycamaro)
Rocky, I don't think you have to disconnect the battery. I recently had my car tuned, which required about 6 chip changes, and we didn't disconnect the battery between chips. I didn't have ANY problems and the car runs great!!!
:flag
Old Jul 27, 2002 | 11:48 AM
vader86's Avatar
vader86
You should disconnect the battery.
You wont like it if you fry a chip.
Old Jul 27, 2002 | 02:25 PM
Mike_'s Avatar
Mike_
Default Re: Putting in a different Chip...quick question. (HighRev03)
I always disconnect it, JMO.
Old Jul 27, 2002 | 03:13 PM
Hendej's Avatar
Hendej
Pulling the ECM fuse should have the same effect - no power to the ECM. Better safe than sorry.
I am changing chips daily without disconnecting anything, no probs, but I have the adaptor that keeps the memcal in place, only the PROM chip comes out. YMMV.
Old Jul 27, 2002 | 04:58 PM
jstkrsn's Avatar
jstkrsn
I used to disconnect the battery because the manual says to, sets the aftermarket alarm off when I reconnect. But then Jim Jones at Traco Engr. who programmed the chip for my 86 said I didn't have to. So I haven't since, and haven't had any trouble. Did my 87 and 92 that way.
Old Jul 27, 2002 | 05:05 PM
VETTENV's Avatar
VETTENV
Cruise-In V Veteran
Cruise-In VI Veteran
Yes, definitely disconnect negative side, unless you have a static strap and a good ground to clip onto. :yesnod: It's easy to disconnect and you'll save the chip! :D
To Putting in a different Chip...quick question.
