Headlights won't stop dinging!
Old Aug 15, 2014 | 09:39 PM
BOOT77's Avatar
BOOT77
Default Headlights won't stop dinging!
I just drove 20 mins home with the headlight dinger going off. As always searched, but didn't find any info. So anyone have this problem before? I could just unhook the dinger but I'd rather fix it right.
Just to be clear, It only dings with the headlights on.
edit: dome is off
Old Aug 16, 2014 | 02:08 AM
Cliff Harris's Avatar
Cliff Harris
That sound comes from the "chime module". It will chime if the headlights are on and the ignition is NOT turned on. The ignition-on signal comes from the ignition switch and goes through the GAUGES fuse.
Old Aug 16, 2014 | 04:22 AM
BOOT77's Avatar
BOOT77
I am hoping it's not the ignition in some way LOL really don't wanna tear apart the column.
Old Aug 16, 2014 | 06:06 PM
BOOT77's Avatar
BOOT77
Tried gauges & cluster fuses and nada. I'll have to look into it more later trying to weld up my C3 headers so I can get it out this year, I'm bout done messing with the C4 for now anyways.
Old Aug 17, 2014 | 02:14 AM
Cliff Harris
The ignition switch is mounted on the steering column near the pedals. It is operated by a rod that is connected to the ignition key cylinder. The position of the switch is adjustable and sometimes they do get out of adjustment.
To Headlights won't stop dinging!
