LS Swap Questions
How does the differential bushing affect installing the cbeam?
Has anyone ever seen a cbeam twist?
Would solid mounting the differential cause problems? If so what kind?
The engine was rebuilt, and has not been started. I have not dealt with engine break in, and I am nervous about killing it.
What should I do, and avoid doing here?
With the cbeam I can get 6 bolt holes lined up, but I cant install 2 bolts.
I am not sure what the problem is that is causing this.
Get a pointy metal bar to help align the holes. I do think these get tweeked with age, no question. But they will go in AS LONG AS THE ENGINE is aligned right. IF the motor is cocked left or right, all bets are off.
You cannot hard mount the diff... it already is!
The trans cannot be, because the floor cannot support the torque loading. Remember, this is a back bone architecture, and the body is simply the body...
The Corvette does not use a "backbone architecture". That is LORE that has been passed on from early misprints of how the car is made and it still persists. Bogus, I'd recommend THIS READING for you, if you have some time. The C4 is a perimeter frame car, the only thing "special" about it is that the body panels are adhered directly to the frame, rather than bolted on top of it...and the C-beam, which simply eliminates the need for a cross member and heavy beams to support the diff. You can use a trans cross member in a C4 (383vet is proof of that), but again, it will add weight and also lower ground clearance.
OP: I'd do what ever I have to do, to get the C-beam to fit and work.
As for engine break in, there isn't much required in modern engines with roller cams, etc. Just make sure the oil pump is charged, start it, and drive it normally for the first bit.
I have noticed that it is always the same 6 bolt holes that line up, and no matter what I try I cant get the 2 bolt holes on top of the differential lined up. The 2 bushings? that mount the differential to the frame need replacing.
I ended up getting a D36 cbeam because my D44 cbeam seems too short. Other then being too long it would work.
PS
I think I need to thoroughly inspect the rear suspension for damage. What points shout I look at the closest? I'm asking because the car has coil-over shocks, and either the RR or RL shock had issues. I was hoping that I could just replace the shock, but now I think I need to look at everything closer. The shock is a QA1 DS502. I am not sure how to explain what happened.
Can you re-drill the C beam?
With the D44 cbeam the new holes would just hit the outside edge, and I doubt there would be enough material for that to work correctly.
The engine is not stock but I am unsure how much power it will make.
In your other thread I suggested you start a thread:
"ANYONE INSTALLED AN LS IN A '92+ LT1 CHASSIS WITH ZF".
There's threads where newer C5/6 brackets to engine were used and either manufactured "solids" or mounts other than something OE. I also think your Novak release is going to be an issue but it's not my build so I didn't look any further.
This is an 11 page read that maybe you could learn from.
http://forums.corvetteforum.com/c4-t...arts-list.html
