Manifold ?'s
Old Jul 27, 2002 | 09:48 PM
LT5's Avatar
LT5
Default Manifold ?'s
I have a 94' LT1 exhaust manifold glowing at cylinders 7& 8. There are no cats on this car and the 02's are fine(new). What could cause this (rich?) condition?
Old Jul 28, 2002 | 12:08 AM
vader86's Avatar
vader86
Default Re: Manifold ?'s (LT5FIRE)
I thought that if they were glowing, then it indicated a lean condition? Maybe the injectors arent pumping enough fuel?
Old Jul 28, 2002 | 01:44 AM
gtsyellow's Avatar
gtsyellow
Default Re: Manifold ?'s (vader86)
do not drive that car till you find the cause, test the air/fuel, look at the plugs, if it stays lean long you WILL put a hole in a piston.
To Manifold ?'s
