#1 drag is frontal area. The more perpendicular to direction of air the worse the drag. (not much you can do about this w/o body work).
#2 is air flowing through engine room, under car, tire wells, and behind rear. This is dirty (turbulent) air flow that adds drag / consumes power. Small things that help are taping off frontal openings and removing the seal between hood and firewall. (lets the high pressure in the cowl area bleed down the firewall and helps sweep away heat off the exhaust)
Best way to help both of those is to lower the car as much as is possible.
Next best thing is to get the engine into the TQ peak as quickly as possible in top gear.
Everything else is just a matter of increasing efficiency of something that is already helping or hurting you.
- Brakes dragging? (do a quick left / right bobble of the steering wheel after you launch to help the front pads move away from the disk)
- Remove mirrors
- Make a true ram air system to help pack the intake w/cool air. In place of the front license plate is a great way to kill two birds with one stone
- Take about 3/4 of a quart of oil out of the engine (from the full mark)
- Install a alternator cut out switch
- Make sure the cabin body vent is operating
- Remove mirrors
I thought that someone talked about this on another thread, possibly Vader and he didn't think that it would help that much. To me it sounds as if you would be getting more air inside the engine compartment, but they were discussing this, and it ended up that it didn't help. I could be wrong since I have had a nap since they last discussed it. Am I wrong? I was sure it was Vader and Cuda, if so, help me out guys.
Tommy
Just know that the C4 Corvette was one of the most aerodynamic cars built in it's day in it's stock form so your way ahead of the game to start with. Below are the numbers for Coefficient of drag......WW
great to see a member doing the standing mile events. I'd like to get involved but first I have to get my car running good. How much power do you make and how fast do you want to go?
It's mildly modified lt4, making somewhere around 420whp. Not enough power to go really fast, just trying to get best out from what I have. I'm not trying to be the fastest guy there, it's more like a learning process.
Last year I did 163mph. My current goal is to make 168mph without touching the engine.
