Brake Issue
Old Aug 24, 2014 | 08:24 PM
Rickyracer6r's Avatar
Rickyracer6r
Default Brake Issue
Hi everyone. My 1991 Coupe had a brake issue yesterday. I was backing out of my garage and had to do some maneuvering. I put her in drive and pulled forward just a bit. As I was about to put her back into reverse (With foot firmly on the brake peddle) she lunged forward and hit my garage! Fortunately only scuffed her a bit. What could this be??? I heard a noise in front of me and then I felt the brake peddle vibrate and heard the rotters and pads chatter then the lunge. All of this happened very quickly with no time for me to react.
Thank you for any help in figuring this issue out.
Old Aug 24, 2014 | 10:11 PM
jv9999's Avatar
jv9999
Sounds like your ABS was getting false information and tried to prevent your wheels from locking up. You might want to pull the ABS fuse until you get a chance to fix it.
Old Aug 24, 2014 | 10:13 PM
GKK's Avatar
GKK
Were the Tires, Rotors or ground wet?
It sounds like the ABS system was activated causing the vibration and pulsing in the brake peddle.
Old Aug 25, 2014 | 09:57 AM
Rickyracer6r
Nothing was wet on or around the car when this happened. I will pull the fuse for the ABS system and figure out what has to be done next.
Thank you guys for your input on this.
You guys Rock!!
Old Aug 25, 2014 | 10:00 AM
Rickyracer6r
Thank you I will pull the fuse and figure out what needs to be done.
Old Aug 25, 2014 | 10:27 PM
gerardvg's Avatar
gerardvg
Hi we feel for you.
Did you hear a hiss? the brake booster is plastic and can crack which limits braking and need more pedal effort. The booster diaphragm leak is usually heard in the car, the external booster needs to be checked run the engine and turn it off listen for any hiss noise.
Also how long did you run the engine, it should develop enough vacuum so check your oneway valve that should hold vacuum for a few brake pedal applications.
I have no problem keeping the car stopped, even if i rev her a little and slam it into reverse or drive.
(Mechanical or pilot error), leaning to mechanical if your booster is leaking or check valve.
Old Aug 26, 2014 | 09:56 AM
TA's Avatar
TA
My car did the same exact thing several times and I believe on mine it was an issue with a bit of air somewhere in the system. When it happened to me it was also while pulling into the garage. I was inching forward, foot on the brake, trying to get to a certain point within the garage. Suddenly it felt as if the ABS kicked on and the car surged forward, probably 10 inches or so. This happened on two occasions. Both did, however, occur after washing the car, so I guess wet brakes could have been an issue also.
Even though I had a firm pedal, I decided to bleed the brakes, as I needed to flush the system anyway. I flushed the everliving snot out of the brakes (at least 5-10 times for each corner) ensuring I got out all the old fluid and any potential air. The car has never done it since.
Old Aug 26, 2014 | 07:48 PM
Rickyracer6r
Originally Posted by gerardvg
Hi we feel for you.
No hissing and she has driven and stopped perfectly since that day. I have noticed that after starting the car once it has sat overnight that It's best if I pump the brake peddle twice before I put her in gear.
Old Aug 26, 2014 | 07:51 PM
Rickyracer6r
Hi we feel for you.
I am going to bleed the brakes on her soon to have that little extra piece of mind.
Thanks to all you guys who have given input on this.
Old Aug 29, 2014 | 02:10 AM
gerardvg's Avatar
gerardvg
Ok some insight, i was backing my company car in the garage looking to clear the door and went a little to close to my vette. hitting the brake pedal sharply activated the ABS brakes. (almost backed the towbar into the front of my corvette)
The concrete floor doesnt have the grip of bitumen, there was some sawdust on the concrete (courtesy of next door neighbour chopping down trees) the garage door was up a bit and quite a bit blow in with the wind.
So there you have it, nothing wrong with your brakes as a similar thing has almost happened to me. (very similar of what happended to you)
You may have a dusty surface and no matter how hard you hit the brake pedal the abs will just keep locking and releasing rapidly due to the slipery surface. Handbrake may have helped?
This may be problem solved for you as your abs did activate in similar circumstances.
What do you think?
To Brake Issue
