Which direction to advance timing?
Old Aug 27, 2014 | 03:15 PM
octaneforce's Avatar
octaneforce
Default Which direction to advance timing?
On my 89 tpi, when im looking down at the distributor cap, do i "tighten" it (turn clockwise) or "loosen" it (turn counterclockwise) to ADVANCE the timing? I did a new cap and rotor and wiggled the distrubitor all over the place. I was planning on advancing it until it pings then backing off. Which is how ive timed everything ive owned lol. I know its ludacris.
Old Aug 27, 2014 | 03:21 PM
WW7's Avatar
WW7
counterclockwise is advance .You really need to get a timing light ..You can get them for $20.00..Not having the timing set exactly right can cause problems....WW
When in dought look on youtube...
Old Aug 27, 2014 | 05:49 PM
MrWillys's Avatar
MrWillys
WW is right, and the electronically controlled spark table is quite complex. Disconnect the brown wire with a black strip and set to 6 degrees on the timing tab BTDC.
Old Aug 27, 2014 | 05:51 PM
Joe C's Avatar
Joe C
Originally Posted by octaneforce
I was planning on advancing it until it pings then backing off. Which is how ive timed everything ive owned lol. I know its ludicrous.
Ludicrous to say the least. do as WW says, and get a timing light. as I recall 6 degrees BTDC is stock - some say the L98 runs a tad better at 8.
Old Aug 28, 2014 | 06:26 PM
aklim's Avatar
aklim
It does sound crazy to advance till it pings since the knock sensor will retard timing as much as it can. Furthermore, you can't be listening for knock under most conditions unless it is more severe. That is what the knock sensor is for.
Old Aug 28, 2014 | 07:13 PM
aklim's Avatar
aklim
Old Aug 28, 2014 | 09:25 PM
octaneforce
Ok so i guess this thing is a little more temperamental than a fox mustang. So 8 degrees? I'll steal my buddy's timing gun tomorrow.
Old Aug 28, 2014 | 09:36 PM
octaneforce
Great video. That frieburger guy from road kill is the best.
Old Aug 28, 2014 | 09:42 PM
aklim's Avatar
aklim
I'd set it at 6 since that is what the ECM is setting the advance off. Mustang is the same. They have their hacks that simply adjust timing any which way and hope for the best. I have my advance set in the EPROM. I had it dyno tuned. If you have a larger waist, getting a set of pants 2 sizes up might also make the legs too long.
Old Aug 29, 2014 | 01:03 AM
Cliff Harris's Avatar
Cliff Harris
6 degrees is programmed into the ECM. If you change it to 8 degrees it probably won't be a problem. If you get too radical with the advance you can get knock because the ECM thinks it's at 6 but has no way to know you changed it to something else. This becomes important at higher RPM when the ECM adds advance.
If you get a custom EPROM you can have it programmed to any initial advance you want so the problem goes away in that case.
To Which direction to advance timing?
