1984 rear upper control arm.
Old Aug 30, 2014 | 02:48 PM
blueshead's Avatar
blueshead
Cruising
Default 1984 rear upper control arm.
Are the rear upper control arms for a 1984 interchangeable or are they designed for one side or the other. They both have the same part numbers so I'm assuming they 're the same . Anyone know for sure?
Old Aug 30, 2014 | 03:38 PM
WVZR-1's Avatar
WVZR-1
If you're talking about the rods that go from the knuckle to the bracket on each side frame rail, yes they would be the same either side.
