Torque #'s for lower a-arm bolts?
Old Jul 29, 2002 | 05:26 AM
BlackRocket's Avatar
BlackRocket
Default Torque #'s for lower a-arm bolts?
Title says it all. Anyone know the correct Torque #'s for the lower a-arm mounting bolts?
Old Jul 29, 2002 | 11:49 AM
Guest
Guest
Posts: n/a
Default Re: Torque #'s for lower a-arm bolts? (BlackRocket)
Don't know if car year matters but the 84 manual says Lower Control Arm Shaft to Crossmember is 96 ft.lbs. Lower Control Arm to Lower Ball Joint 48 ft.lbs. Shock to lower control arm is 22 ft.lbs.
Torque values with car on the ground.
HTH
Mark
Old Jul 29, 2002 | 02:33 PM
CAJUN C4's Avatar
CAJUN C4
Default Re: Torque #'s for lower a-arm bolts? (Mark84_L383)
Good Job Breeze !
Old Jul 30, 2002 | 07:08 PM
Guest
Guest
Posts: n/a
Default Re: Torque #'s for lower a-arm bolts? (CAJUN C4)
Hey Boudro that you would have changed that sig by now. :yesnod: :p:
Old Jul 30, 2002 | 10:15 PM
1MoorTym's Avatar
1MoorTym
:yesnod: I think so.
My 89 man. says - 82 ft lbs. for the lower control arm, 19 ft lbs. for the shock and 50 ft lbs. for ball joint to knuckle nut.
Old Jul 31, 2002 | 09:56 AM
CAJUN C4's Avatar
CAJUN C4
Breeze
It won't be Long Now....What u up 2 ?
To Torque #'s for lower a-arm bolts?
