Intake manifold gaskets/The Right Stuff Questions
Old Sep 4, 2014 | 07:59 PM
AustinJohn's Avatar
AustinJohn
Default Intake manifold gaskets/The Right Stuff Questions
Searching through the posts before replacing the intake manifold gaskets on my '94 LT1 I want to be sure I'm following the latest consensus approach and have two questions.
First, there seems to be consensus that The Right Stuff is the best sealant to use for the end seals. The Right Stuff comes in three flavors; I assume the one to use is The Right Stuff "Black Label" (the 4oz power can is PN 25223), right?
Second, the consensus seems to be no sealant on the gaskets themselves, right?
Interestingly the TDS for the product says "Re-torque will not be necessary after the product has cured" but I assume most folks do re-torque.
Thanks a million. John
Old Sep 4, 2014 | 08:30 PM
383vett's Avatar
383vett
Correct about the Right Stuff Black. I always coat both sides of my FelPro intake gaskets (1205) with a very think coat of Permatex Ultra Blue. Haven't had an intake leak in dozens of intakes over the years. Retorque optional. Everyone does it different.
Old Sep 4, 2014 | 08:42 PM
HlhnEast's Avatar
HlhnEast
If your talking intake to head, yes use Right Stuff black on the china wall, a good 3/8" bead. I used gasket tack on the actual head to manifold gasket to hold the gasket in place while I fumble around finding bolt holes. It is also a good sealant so nothing else needed. As for intake to runners and runners to plenum, I used nothing, just torqued to spec with no issues.
Oh and a dab of RTV on the intake bolts to make sure no oil creeps up the threads and puddles on your manifold.
Old Sep 4, 2014 | 08:43 PM
AustinJohn's Avatar
AustinJohn
Many thanks. John
Old Sep 4, 2014 | 08:47 PM
AustinJohn's Avatar
AustinJohn
Do you use Never Seez and RTV on the intake bolts or just RTV? John
Old Sep 4, 2014 | 10:22 PM
HlhnEast's Avatar
HlhnEast
Just a small dab enough to cover a couple of threads towards the top of the bolt. It will spread out on its own and help seal the threads up. If you use too much it will cause a kinda hydraulic pressure and may strip out the threads so be careful. If it acts like it is bottoming out before it looks like its made up, pull it back out and clean some of the RTV off. Not trying to scare ya, just be careful.
Old Sep 5, 2014 | 12:08 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
On my '88 I rough up and dimple the two china wall lands and rough up the mating intake base portions. I like to use two beads of black RTV to assure "enough".
For the gaskets I use a little RTV around the water passages and trail it down to the lands.
Set the intake base straight down into position; avoid any sliding motion. Tighten all the intake base bolts in seqence and steps to spec; use some Permatex on the bolt threads. BTW, all bolt holes had been chaced to remove any debris.
Once the base is torqued to spec, walk away and let it set for at least 24hrs for the RTV or RS to completely cure.
Old Sep 5, 2014 | 06:39 AM
AustinJohn's Avatar
AustinJohn
Thanks. John
AustinJohn's Avatar
AustinJohn
Thanks. John
Old Sep 5, 2014 | 08:50 AM
cudamax's Avatar
cudamax
Only the 4 corner bolt holes have bottoms. Those are the only ones to watch for too much. All the others don't have a bottom and go through. Use nothing but non-hardening permatex on all the bolt threads. Incase you need to re-torque and so you don't get any oil leaks thru the middle holes. A little blue on the port sides only and on both sides, if the heads have been cut/milled and black on the ends. Leaving it to cure before a start up
To Intake manifold gaskets/The Right Stuff Questions
