Upgrade Fuel injectors?
Old Jul 29, 2002 | 12:17 PM
dsg049c's Avatar
dsg049c
Default Upgrade Fuel injectors?
Do I need to upgrade my fuel injectors? Here is my set up..
LT1 converting to a LT4, LT4 heads ported and polished, LT4 intake,
LT4 Hot cam, 52mm throttle body, Vortech ram air, fuel pressure regulator.. Custom program (Ed Wright). I am rebuilding my motor and it is already striped down, when we put it back together should I replace the injectors? I was going to upgrade them to the Accell 30lb injectors... Do I need to? will the help ? Or is the stock #24 injectors ok? The LT4's came with #28...
:seeya
Old Jul 29, 2002 | 12:24 PM
STL94LT1's Avatar
STL94LT1
Default Re: Upgrade Fuel injectors? (dsg049c)
I have been researching the same upgrade to my car, and I've been told by several tuners "no"'
