Leak down test help
Old Sep 6, 2014 | 04:33 PM
DanielRicany's Avatar
DanielRicany
Default Leak down test help
Hi guys. I have a 1985 Corvette. I also have AFR 195 Eliminator heads.
My timing chain broke and took out 3 valves.
Here were my leak down test results from before I pulled the heads off with the bent valves.
1. 20%
2. 13%
3. 95% intake
4. 13%
5. 95% exhaust
6. 15%
7. 95% exhaust
8. 20%
I took my heads to the machine shop and had a valve job done on both heads.
When I bolted the heads on, I took another leak down test. The engine is cold and I haven't ran it yet. I did wipe oil on the cylinder walls, and there is no oil in it right now.
About 3 of my cylinders were above 30% with a peak of 36%. The lowest cylinder I believe was 17%. I was just wondering if this is a normal result for a cold engine with new head gaskets and a fresh valve job? Is there a time it takes to seat in?
Thank you.
Old Sep 6, 2014 | 05:30 PM
DanielRicany
I took another leak down test and recorded the results. Here they are:
1. 31%
2. 32%
3. 18%
4. 21%
5. 19%
6. 36%
7. 21%
8. 31%
Old Sep 6, 2014 | 06:35 PM
383vett's Avatar
383vett
That's a lot of leakage, especially if you oiled the cylinder walls. The fresh heads should seal completely; the valves should be tight on their seats. Can you tell where the air is leaking? exhaust, throttle body, valve cover filler cap? The air is going somewhere.
Old Sep 6, 2014 | 06:37 PM
DanielRicany
Through the valves. I sprayed some PB blaster into the intake port on the cylinder that has 36%. Put the leak down tester on it. Here's a video of what happened. http://youtu.be/KH7r0SwNCh0
Old Sep 6, 2014 | 09:20 PM
383vett's Avatar
383vett
Tell the machine shop they did a crappy job.
Old Sep 7, 2014 | 12:18 PM
DanielRicany
I'm going back to the machine shop this week. Do I need to lap the valves after a valve job?
Old Sep 7, 2014 | 12:49 PM
C409's Avatar
C409
...... Did you adjust the valves before the second leakdown ? If so , you may have done it wrong ... its easy to screw up using the spin the pushrod method and you wind up with valves off seats instead of just pre-loaded .........
Old Sep 7, 2014 | 12:56 PM
DanielRicany
No I didn't have the rocker arms on when I did this test.
Old Sep 7, 2014 | 01:24 PM
ex-x-fire's Avatar
ex-x-fire
Hit the valve stems with a soft faced hammer & retest. Sometimes the valves need to snap shut to seal.
Old Sep 7, 2014 | 01:36 PM
383vett's Avatar
383vett
They are all leaking. With 130lbs closing pressure, a closed valve is closed. My money is on a lously valve job. After a good valve job is done, alcohol can be poured on the top of the valve. There should be no leakage.
Old Sep 7, 2014 | 02:22 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
100%. That video tells the story....assuming clean assembly.
Old Sep 7, 2014 | 03:38 PM
DanielRicany
I poured lacquer thinner in the ports of the valves and it didn't leak through, but it still leaks on the engine...
Old Sep 7, 2014 | 06:04 PM
383vett's Avatar
383vett
Can't figure how the valves hold laquer thinner but leak down so badly.
Old Sep 7, 2014 | 06:12 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Well, thats how most of Daniel's stories go; he has "great leak down numbers", but tons of blow-by (from a previous thread). Go figure.
Old Sep 7, 2014 | 06:48 PM
DanielRicany
Me neither. But I don't think it's the rings because you can see the valves leaking air into the pb blaster. And because it was better results right before I removed the heads.
Old Sep 8, 2014 | 11:21 AM
DanielRicany
I made a little break through. I poured a little bit of oil into cylinder 6 which had 36% leak down. That's also the affected cylinder in the video or the valve with the PB blaster bubbling. Now when I did the test again, it now has 18% leak down. So is the amount of air escaping get out of the valves acceptable for a cold leak down test if the oil dropped it significantly?
Thanks guys
Old Sep 8, 2014 | 12:01 PM
Dega500's Avatar
Dega500
Very interested in this thread. Thanks OP! I have been reading up on leak down tests but have not ever performed one. Just curious what psi your pumping into the engine?
To Leak down test help
Old Sep 8, 2014 | 12:04 PM
DanielRicany
100 psi as instructed by the snap on leak down tester instructions.
Old Sep 8, 2014 | 04:45 PM
383vett's Avatar
383vett
I should have known better.
Old Sep 8, 2014 | 04:49 PM
DanielRicany
Called the machinist, told me to run the motor for 10 minutes and check again. Said the valves have to seat... I'm doing a compression test on all cylinders now. Getting pretty decent results and the only cylinder i put oil in was number 6. Also there's no oil in the motor during this test. I'll post the results in a few minutes when I finish.
