Idle is set too high..How do I readjust it...
Old Jul 29, 2002 | 01:36 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default Idle is set too high..How do I readjust it...
How do I get my idle down like 800rpms....?
Right now I have turned the screw on the throttle body in and yes this did work ....to a degree...the idle is now lower....BUT...only when I blip the throttle....something is catching or holding it back....
I checked the throttlebody thoroughly and nothing appears wrong...the one thing I did notice was that.....the throttle sticks when the car is turned on and running....but when turned off, the pressure and tension on the throttle cable is loose enough to allow the throttle body plates to close completely.
Could my computer and IAC be fighting what I did by turning the idle screw on the throttle body?
if so....whats the procedure to resetting the IAC.....if I remember correctly...you have to jumper the ALDL connector or something....
thanks
jeff :cool:
[Modified by XtremeVette, 11:37 AM 7/29/2002]
Old Jul 29, 2002 | 02:01 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Idle is set too high..How do I readjust it... (XtremeVette)
My method is on my site; skip the second part about setting the TPS as yours isn't adjustable.
Old Jul 29, 2002 | 02:12 PM
XtremeVette
Default Re: Idle is set too high..How do I readjust it... (65Z01)
perfect....thanks!
I knew this info was out here somewhere....
Jeff :crazy:
To Idle is set too high..How do I readjust it...
