84 smoke from under hood
Old Sep 8, 2014 | 08:00 PM
ToniJ1960's Avatar
ToniJ1960
Default 84 smoke from under hood
I knew there was some kind of oil leak in t he car, and once in a while I see smoke coming from the vent area.
Wasnt sure if it was blowby (there is some) sneaking back in, a manifold leak under the hood (someone told me they though tthere is one), valve covers leaking. Maybe the oil pressure sender even.
Today I pulled in my drive, and smoke was coming from under the hood. Shut the engine down it seemed to stop a minute later more smoke. Waited in the car a minute, seemed to stop. Got out it started again. I was thinking oh sht its going to burst into flames oxygen is feeding it or something.
Havent gone back out o check it yet.
Old Sep 8, 2014 | 10:07 PM
Ahnenerbe's Avatar
Ahnenerbe
[QUOTE=ToniJ1960;1587786903]I knew there was some kind of oil leak in t he car, and once in a while I see smoke coming from the vent area.
My bet is you have a valve cover leak where it is leaking onto manifolds causing smoke, the next thing would be sending unit dripping onto exhaust pipes.
Old Sep 8, 2014 | 10:43 PM
ToniJ1960's Avatar
ToniJ1960
Thank you first two things I plan to check, might go out there with a flashlight tonight. Maybe in the dark reflections will show better even.
Old Sep 9, 2014 | 12:03 AM
ToniJ1960's Avatar
ToniJ1960
I looked around with a flashlight and see some oil has been leaking around the block from the valve covers, but doesnt seem like it could be getting on any exhaust. Except maybe some on the flange on the drivers side where the pipes go on the head.
But looking under the car with the engine running theres a drip right around the oil filter area. It seems like its maybe above the filter running down and nicking the exhaust pipe maybe splashing off it.
Is there a fitting that the filter goes onto that can develop a leak?
Old Sep 9, 2014 | 01:04 AM
Cliff Harris's Avatar
Cliff Harris
The oil temperature sensor is above the oil filter on the side of the block. It might be leaking from there. More likely to be a valve cover leak.
Old Sep 9, 2014 | 02:00 AM
ToniJ1960's Avatar
ToniJ1960
If it leaks at the back of the head area would it drip from around the filter?
Old Sep 9, 2014 | 10:38 AM
383vett's Avatar
383vett
You just have to clean the whole area with a rag and solvent (BrakeKleen), start up the motor with the hood up and see where the oil is hitting the exhaust. It helps to have the car on jackstands.
To 84 smoke from under hood
