Strange issue: Engine stalls at 180 degrees
Old Sep 10, 2014 | 10:10 AM
mixalive's Avatar
mixalive
Default Strange issue: Engine stalls at 180 degrees
I have a strange issue where my engine stalls at approx 180-181 degrees. The back story: My Daughter's school is 5 miles from the house. For the past 4 days, as I am taking her to school, my 92 base model consistently stalls within 100 yards of her school. While observing the digital coolant temperature gauge, I notice the coolant just reaches 180-181 degrees when I get to her school. It is like one or two big hesitations. And yes, I have an 180 degree thermostat in the vehicle. I do not receive any ck engine type lights. I will tell you that I received a low coolant light last week and I did top off the coolant at the filler and the overflow reservoir. Maybe I need to bleed the coolant system. Can anyone tell me what is going on here.
Old Sep 10, 2014 | 10:35 AM
C409's Avatar
C409
..... Ohm test the injectors ... they should ALL be around 16ohms ... and , if no spark , have the Ignition control module checked/replaced ... beyond that , start thinking new Opti-Spark ........
Old Sep 10, 2014 | 03:38 PM
mixalive's Avatar
mixalive
Thanks..
Old Sep 11, 2014 | 08:51 AM
mixalive's Avatar
mixalive
It did it at 178 coolant temp today. Please explain to me how if one of my injectors was out of resistant specification, it would shut them all off.
Old Sep 11, 2014 | 09:19 AM
c4cruiser's Avatar
c4cruiser
Originally Posted by C409
..... start thinking new Opti-Spark ........
Sounds like the Opti is ready to die. If you have had to add coolant, it could be that the water pump is leaking coolant onto the Opti.
Old Sep 11, 2014 | 09:47 PM
jv9999's Avatar
jv9999
It could be stalling when it goes into closed loop. You might want to monitor it or disconnect an O2 sensor to keep it in open loop just for a test.
Old Sep 12, 2014 | 07:06 AM
mixalive's Avatar
mixalive
That would make sense. I will try that and report.
Old Sep 12, 2014 | 05:40 PM
C409's Avatar
C409
..... The injectors share a common power source AND a common ground feedback to the drivers in the ECM ... if any one injector is out of spec , it will affect the pulse width of ALL ..........
Old Sep 12, 2014 | 05:53 PM
1993C4LT1's Avatar
1993C4LT1
Get the noid light for the LT1 engine. When it stalls, disconnect a fuel injector connector. Plug in noid light, when the car cranks, if you don't see the noid light lighting up, it's opti. I did this on both of my 93 C4s.
Old Sep 13, 2014 | 08:49 AM
mixalive's Avatar
mixalive
Great information. Thanks.
Old Sep 13, 2014 | 08:53 AM
mixalive's Avatar
mixalive
Got it..
Old Sep 13, 2014 | 01:42 PM
mixalive's Avatar
mixalive
I am getting 12.3 to 12.7 ohms. Is that too low?
To Strange issue: Engine stalls at 180 degrees
