SES?
Old Jul 29, 2002 | 04:40 PM
Damien89's Avatar
Damien89
Default SES?
How do you check the diagnostic conector without having some type of scanner because the ses light stays on some times i start my 89' vette and were do the codes display? :cheers:
Old Jul 29, 2002 | 04:45 PM
scorp508's Avatar
scorp508
Use a paperclip to connect terminals (oh boy, major brain fart here) I think A and G together on your ALDL connector under the dash. It is by your right knee while driving. I think they are the upper right and lower right terminals.
The SES light will then...
FLASH <small pause>
FLASH FLASH
This means "12" and that it is entering diagnostic mode. Any codes you have will then flash in the same manner with a longer pause after the 12.
If you got this sequence....
FLASH <small pause>
FLASH FLASH <longer pause>
FLASH FLASH FLASH <small pause>
FLASH <small pause>
FLASH FLASH
That means 12, 32, 12.
The 12s mean it is entering and exiting diagnostic mode and you have a code 32 set.
Old Jul 29, 2002 | 04:51 PM
Damien89's Avatar
Damien89
Default Re: (scorp508)
THanks a lot scorp508 :cheers:
To SES?
