Getting LT4 Hot Cam kit installed, do I need anything else?
[Modified by Nathan Plemons, 3:35 PM 7/29/2002]
If not the water pump driveshaft seal will get kinked causing an oil leak, slow at first, and then get worse.
The protector looks like a thimble. The GM part number is in the service manual under reinstalling timing cover.(or water pump, can't remember)
If it's got a lot of miles on it replace it.
Update it so that it's vented either with the kit or a new opti.
of course new plugs/wires, a lot easier to replace them now.
All new seals on the timing cover, crank, opti, waterpump drive.
New waterpump if old, before it takes out the opti you just upgraded.
The LT4 Hot Cam was originally developed for showroom stock road racing. Not only does it need the hollow stem LT4 valves to RPM but it needs the much better air flow capacity of the LT4 cylinder head and a low restriction exhaust system to really work well.
On an LT1 with standard valves, stock heads and stock exhaust do not expect a large power gain.
Sure you've got a very valid point, valve float is always a possibility. However, the hot cam is a proven performer in the LT1 engine, valve float is not really an issue. The Hot Cam peaks it's power right at 6000, reving it much past there really isn't that much of a benefit. So by setting the limiter around 6300 or so a good set of springs will easily prevent valve float.
Lightweight valves are always a good thing, but the hot cam does not mandate them.
I added a set of Long tube headers and kicked those numbers up to 336 and 345 respectively. The car runs 12's @ 112 mph. I think that's a pretty good performance increase, all on stock cylinder heads with stock valves.
Don't get me wrong, you bring some good points and some good concerns, but a properly set up hot cam kit doesn't run into the problems you mention.
Eric
Does someone know the part number of the Comp Cams valve springs that can be used with the Hot cam in an LT4? The LT4 already has the Ti retainers and keepers, right?
The two options I see are the Crane 10308 spring/retainer kit (~$146) which has the Crane 1.460" double springs, 99893 springs or the COMP 987 springs. For Ti retainers I'm still looking. K-Motion has a set for 1.460" springs, they should fit the Crane 99893 springs, but I'm not sure.
BTW, MVR 155 dropped a valve with the LT4 HOT cam/LT4 springs combo. He's building a 383 as we speak/write.
Eric
Eric
- This topic is like discussing religion and politics. Everyone has an opinion and different views are not necessarily wrong
- There are better spring combo's out there, and some of them have been listed.
- Most of the better combo's require machining of the valve spring seat. The stock spring is 1.32" OD. A 1.43" OD spring may fit, but it's real close.
- If you go to a different spring, you'll likely need to find new spring seats. The stock LT4 seats have a locator that won't fit "narrow" springs or dual springs with an ID of <.885". I actually bought different springs but returned them because I couldn't find a suitable seat. The GM ZZ3 valve spring spacer (p/n 10185066) may have worked, but I couldn't determine that conclusively.
- While it's true that MVR 155 dropped a valve, he's a single data point. There are several other LT4 owners using LT4 springs without issue even though their cars see 1/4 mile and/or road race use.
- Carefully consider how you'll be using the car. My approach will be to set my fuel cutoff at 6700, but I plan to shift at 6500. My GS sees about 2,500 miles/year with 6 or so trips to the track. Since my goal is just to have fun when I am at the track (I recognized long ago I'm got good enough or wealthy enough to be truly competitive!), I don't go 10/10ths / *****-to-the-wall (i.e. powershifting, etc).
- Don't confuse LT1 info with LT4. The LT4 has lightweight valves, significantly lighter than the LT1 pieces. This is one of the reasons the LT4 springs will work on the LT4 but not necessarily on the LT1 (above 6200 for any length of time).
Hope some of this helps. If money and time aren't an issue and you intend to beat the engine into the ground, I'd pull the heads and have good springs installed (along with some port work as well!! :yesnod: ) If the intended use is typically going to be easy street duty with a touch of stop light drag and track action, I'd go with the LT4 springs.
:cheers:
Jim Mason
'96 Grand Sport #007
He confirmed that the stock LT4 springs are not good enough for the hotcam. You can use the Comp Cams valve springs set 941 for the LT4 hotcam. Set it up with 1” 970. That puts about 120-125 lbs on the seat and 340-350 lbs open.
He says that with an LT4 you need to port the intake because there is a 12% flow restriction unlike the LT1. In fact, he insists on an intake port job with the LT4 heads he does. He says the intake alone is worth 11hp (crank I think) on a stock LT4. The better intake gasket is worth something on the high end as well.
